Topic: LCD Screen and LED no longer blinking when changing power sources (Read 567 times) previous topic - next topic
predzZzZzZ
I am using a 20x4 LCD screen to display certain recorded values. I get it to work when it is connected to my computer, however, once I change it to be plugged into a battery or wall outlet the display just displays white boxes on the 1st and 3rd rows. I have clearly updated a code to it but it still doesn't work. The led that I have connected also doesn't blink when it is plugged into battery or wall outlet either. I was wondering why the difference in output when power source changes and any potential fixes. Thank you in advance.
LCD Screen: https://www.amazon.com/gp/product/B0080DYTZQ/ref=s9u_simh_gw_i1?ie=UTF8&fpl=fresh&pd_rd_i=B0080DYTZQ&pd_rd_r=fae5e15f-fe1f-11e7-bd6b-0356965b604e&pd_rd_w=hHfld&pd_rd_wg=jsWEF&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=&pf_rd_r=0JQ9RET26YK58SP17G92&pf_rd_t=36701&pf_rd_p=d9f78c36-24d5-402e-866f-a50358a0504c&pf_rd_i=desktop
LED: https://www.amazon.com/gp/product/B00KWGJWYM/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
Code: [Select]
#include <Wire.h>
#include <LCD.h>
LiquidCrystal_I2C lcd(0x27,2,1,0,4,5,6,7);
const int ledPin = 13;
int ledState = LOW;
unsigned long previousMillis = 0;
  pinMode(ledPin, OUTPUT);
  lcd.setBacklightPin(3,POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.begin(16, 2);
  lcd.setCursor(0,0);
  lcd.print("RPM = ");
  lcd.setCursor(0,1);
  lcd.print("Temp (F) = ");
  lcd.setCursor(20,0);
  lcd.print("Bearing Life = ");
  unsigned int interval = analogRead(A2);
  if (currentMillis - previousMillis >= interval) {
    lcd.setCursor(6,0);
    lcd.print(interval);
    digitalWrite(ledPin, !digitalRead(ledPin));
ieee488
You have not shown how the LEDs and LCD are connected to your Arduino and to your power source.
Did you think that does not matter?
predzZzZzZ
The power source is from the power jack using a wall adapter, and the other is from the USB connector. To answer your question yes I do think it matters, however it works completely fine when it is connected via USB to my computer, but not on the power jack. I can post pictures however I do not see why that would change the output.
ieee488
Yeah photos.
predzZzZzZ
Here are some images I have included.
predzZzZzZ
These two images exceeded file size on the last post.
Wawa
It seems that the pot is plugged into the wrong holes of the breadboard.
Leo..
