Topic: Bootloader failure wrong device signature (Read 23540 times) previous topic - next topic
Mr._Swarf
System: Mac IDE 0022
Programmer: USBasp
Board: EMSL Diavolino with 328P
avrdude 5.8cvs
I'm trying to upload a bootloader to a new virgin 328p. I've added the USBasp device to my programmers.txt file.
When I tell the IDE to burn the bootloader I get an error about device signature.
If I unplug the usbasp programmer from the computer then plug it back in and run avrdude -c usbasp -p m328p from a console window everything looks fine. Run the same command again and I get the device signature error. Unplug and repeat, same deal.
Here's the output on the console:
Code: [Select]
MacBook:arduino testing$ avrdude -c usbasp -p m328p
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
avrdude: Device signature = 0x000102
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
         Double check chip, or use -F to override this check.
This is the same error I get from the Arduino IDE.
I'm still very new to the Arduino so I'm pretty much stumped. An hour or so of Googleing has not been any help.
Ideas??
M.S.
Coding Badly
What changes did you make to boards.txt?  Which board did you select in the IDE?
Mr._Swarf
Basically I copied the Duemilanove w/328 entry, renamed all the lines from atmega328 to atmega328p and changed the upload protocol to usbasp.
I then selected that board in the IDE prior to attempting a burn.
Code: [Select]
atmega328p.name=ATmega328 USBasp
atmega328p.upload.protocol=usbasp
atmega328p.upload.maximum_size=30720
atmega328p.upload.speed=57600
atmega328p.bootloader.low_fuses=0xFF
atmega328p.bootloader.high_fuses=0xDA
atmega328p.bootloader.extended_fuses=0x05
atmega328p.bootloader.path=atmega
atmega328p.bootloader.file=ATmegaBOOT_168_atmega328.hex
atmega328p.bootloader.unlock_bits=0x3F
atmega328p.bootloader.lock_bits=0x0F
atmega328p.build.mcu=atmega328p
atmega328p.build.f_cpu=16000000L
atmega328p.build.core=arduino
M.S.
Coding Badly
Code: [Select]
avrdude -c usbasp -p m328p -v -v -v
...run it twice.  We're after the fuse settings (first run) and an idea of when exactly the failure happens (second run).
Mr._Swarf
#4
Feb 16, 2011, 04:14 am Last Edit: Feb 16, 2011, 04:17 am by Mr. Swarf Reason: 1
Here's the output from this on my linux box: (it gives the same error as on my Mac)
(This is the first run of the command. Second in next post as it's too long for one post)
Code: [Select]
twmaster@Penguin:~$ sudo avrdude -c usbasp -p m328p -v -v -v
[sudo] password for twmaster:
avrdude: Version 5.10, compiled on Jun 29 2010 at 21:09:48
        Copyright (c) 2007-2009 Joerg Wunsch
        System wide configuration file is "/etc/avrdude.conf"
        User configuration file is "/home/twmaster/.avrduderc"
        User configuration file does not exist or is not a regular file, skipping
        Using Port                    : /dev/parport0
        Using Programmer              : usbasp
avrdude: seen device from vendor ->www.fischl.de<-
avrdude: seen product ->USBasp<-
        AVR Part                      : ATMEGA328P
        Chip Erase delay              : 9000 us
        PAGEL                         : PD7
        BS2                           : PC2
        RESET disposition             : dedicated
        RETRY pulse                   : SCK
        serial program mode           : yes
        parallel program mode         : yes
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
                                 Block Poll               Page                       Polled
          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
          eeprom        65     5     4    0 no       1024    4      0  3600  3600 0xff 0xff
          flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
          lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : usbasp
        Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: safemode read 1, lfuse value: ff
avrdude: safemode read 2, lfuse value: ff
avrdude: safemode read 3, lfuse value: ff
avrdude: safemode: lfuse reads as FF
avrdude: safemode read 1, hfuse value: da
avrdude: safemode read 2, hfuse value: da
avrdude: safemode read 3, hfuse value: da
avrdude: safemode: hfuse reads as DA
avrdude: safemode read 1, efuse value: 5
avrdude: safemode read 2, efuse value: 5
avrdude: safemode read 3, efuse value: 5
avrdude: safemode: efuse reads as 5
M.S.
Mr._Swarf
Ok, second run of the program:
Code: [Select]
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
M.S.
Coding Badly
Do you have an 8+ MHz crystal connect to the target processor?
Mr._Swarf
#7
Feb 16, 2011, 04:27 am Last Edit: Feb 16, 2011, 04:34 am by Mr. Swarf Reason: 1
16MHZ on the target board. It's a Duemilanove clone.
M.S.
Mr._Swarf
Also, if this matters... The USBasp board I'm using has a mega8L onboard.
I wonder if some sort of reset is somehow causing avrdude to see the mega8 instead??
M.S.
Coding Badly
Good theory!  Unfortunately, that isn't the case...
Quote
Quote
For the ATmega8 the signature bytes are:
1. 0x000: 0x1E (indicates manufactured by Atmel).
2. 0x001: 0x93 (indicates 8KB Flash memory).
3. 0x002: 0x07 (indicates ATmega8 device).
... 0x1E9307 != 0x000102
Maybe you have it backwards.  Maybe the programmer is not being reset between runs.  Maybe the "0x000102" is something leftover from the previous run.  I assume the USBasp has some sort of serial-to-TTL converter on it.  Normally, when an Arduino serial port is opened, DTR is fiddled to reset the board.  Is this also true of a USBasp?  Is it supposed to be reset by something like DTR?
How are you powering the target?
Sidebar: How did you get a processor with no markings?
Mr._Swarf
Alrighty then....
The USBasp is from this design: http://www.fischl.de/usbasp/
It does not have any TTL to serial conversions on the thing. Some resistors and diodes connect from the USB to the AVR on the asp board.
No idea if it is supposed to be reset by twiddling anything via serial commands.
The USBasp and the Diavolino are powered off the USB port. Although there is a jumper to disable power to the target board.
And the 328 has markings. Look closer at the pic. And, yea, they are as hard to read in person as in the photo.
I should add that I now have a bootloader on the AVR. I used a Seeeduino as an ArduinoISP.
What a mystery...
M.S.
Coding Badly
Quote
That might be the key...
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=74739&start=0
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=52971&start=0
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&p=167745
...seems to be a symptom of a hardware problem.  Try powering the board independently from the programmer.
http://www.google.com/search?q=avrdude%3A+Device+signature+%3D+0x000102
Mr._Swarf
#12
Feb 16, 2011, 10:32 am Last Edit: Feb 16, 2011, 10:34 am by Mr. Swarf Reason: 1
One step forward, one step backwards... Wheeeeeee!
It appears I have solved the problem leading to the device signature error.
Miss wired 10 pin to 6 pin ISP cable. You all may strike me with a clue bat at will.
I've rewired and double checked. It now works every time on both my Linux workstation and MacBook. At least it works with the commands as above.
I really need to find an avrdude for utter morons tutorial.
I still cannot burn a boot loader from the IDE with this usbasp programmer on either system yet. And I seem to have somehow bricked my new 328P...
I'll pick up the fight tomorrow. It's late. I'm tired and grumpy.
Thanks for taking the time to help.
M.S.
