Topic: 2 power supplies with ws2812b? (Read 718 times) previous topic - next topic
DeXan74
Hi all,
So after many hours reading and searching I would like a definitive answer for my simple(?) wiring set up please.
I have an Arduino UNO R3 with 2 x WS2812b strips of 30l/m.
I am making two arch strips with 86 leds each. Total = 172 leds
Each strip will be controlled separately (using Pin 12 and Pin 13).
My initial calculations are as follows and I am happy with this so far (with some more tweaking).
Full bright(256) = 60ma * 172 = 10.3 amps (I will not use all white so this is worse case...)
I will reduce brightness to 100 in my code, 100/256 * 60 *172 =  4.03amps
My issue is do I want them powered separately using 2 x 5volt 4amp power supplies, or just use one in the centre of my project. I would like to consider both wiring options please.
I know we need to tie the grounds, but do I just join ALL the ground wires to each other and the Arduino?
Does this interfere with the Data of the separate strips somehow?
My Diagram shows 2 power supplies - it is only my starting point.
Cheers,
DeXan
larryd
#1
Jan 22, 2018, 07:21 pm Last Edit: Jan 22, 2018, 07:22 pm by larryd
Then why isn't the top GND commoned?
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
DeXan74
I tried once and blew the first LED, so I was wondering if the Data line would be OK if I did this.
Is this (updated) diagram all we need to do to safely achieve this goal?
Thanks.
Grumpy_Mike
Then something else was wrong.
No it is not.
