Topic: Using Nrf24l01 to send sensor data in integer (Read 1 time) previous topic - next topic
Farhan_tech
I want to sent integer value of a sensor with a Nrf24l01. I can ON/OFF led or relay but dont know how to send sensor value wirelessly with Nrf24l01.
my tx code
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include<dht.h>
dht DHT;
#define DHT11_PIN 3 // if you require to change the pin number, Edit the pin with your arduino pin.
int DataMsg[1];
RF24 radio(9,10);
const uint64_t pipe = 0xE14BC8F482LL;
int Button1 = 7;
int Button2 = 2;
  pinMode(7, INPUT);
  digitalWrite(7,HIGH);
  pinMode(2, INPUT);
  digitalWrite(2,HIGH);
  Serial.println("NRF24L01 Transmitter");
  Serial.println("welcome to TechPonder Humidity and temperature Detector");
  radio.begin();
  radio.openWritingPipe(pipe);
  int chk = DHT.read11(DHT11_PIN);
Serial.println(" Humidity " );
Serial.println(DHT.humidity, 1);
Serial.println(" Temparature ");
Serial.println(DHT.temperature, 1);
 radio.read(&DHT.temperature, sizeof(DHT.temperature));
delay(2000);
   if (digitalRead(Button1) == LOW)
    Serial.println("Button 1 pressed");
    DataMsg[0] = 1;
    radio.write(DataMsg, 1);
  if (digitalRead(Button2) == LOW)
    Serial.println("Button 2 pressed");
    DataMsg[0] = 2;
while(Serial.available())
  char In=Serial.read();
    if (In=='2' == HIGH)//relay on
      Serial.println("Relay ON");
      DataMsg[0] = 1;
    DataMsg[0] = 1;
    if (In=='1' == HIGH)//relay on
      Serial.println("Relay OFF");//relay off
      DataMsg[0] = 2;
    DataMsg[0] = 2;
    if (In=='4' == HIGH)//relay on
      Serial.println("LED ON");
      DataMsg[0] = 3;
    radio.write(DataMsg, 3);
    DataMsg[0] = 3;
if (In=='3' == HIGH)// on
      Serial.println("LED OFF");//relay off
      DataMsg[0] = 4;
    DataMsg[0] = 4;
if (In=='6' == HIGH)//relay on
      DataMsg[0] = 5;
    radio.write(DataMsg, 5);
    DataMsg[0] = 5;
if (In=='5' == HIGH)// on
      DataMsg[0] = 6;
    DataMsg[0] = 6;
My rx code
#include <SPI.h>
#include "RF24.h"
int DataMgs[3];
RF24 radio(9,10);
int Relay1 = 2;
int LED1 = 4;
int LED2 = 3;
  pinMode(Relay1, OUTPUT);
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  radio.begin();
  radio.openReadingPipe(1,pipe);
  radio.startListening();
  if (radio.available())
    bool done = false;
    while (!done)
      done = radio.read(DataMgs, 1);
      Serial.print("NRF24L01 Receiver: ");
      Serial.println(DataMgs[0]);
      if (DataMgs[0] == 1)
        delay(10);
        digitalWrite(Relay1, HIGH);
      if (DataMgs[0] == 2)
        delay(10);
        digitalWrite(Relay1, LOW);
      if (DataMgs[0] == 3)
        delay(10);
        digitalWrite(LED1, HIGH);
      if (DataMgs[0] == 4)
        delay(10);
        digitalWrite(LED1, LOW);
      if (DataMgs[0] == 5)
        delay(10);
        digitalWrite(LED2, HIGH);
      if (DataMgs[0] == 6)
        delay(10);
        digitalWrite(LED2, LOW);
      delay(100);
  Serial.println("Waiting for signal...");
