Topic: Uno Vista Problem (Read 1 time) previous topic - next topic
bkbradley
I'm trying to install the driver for an Arduino Uno to no avail. I'm using a Dell laptop with ,multiple USB ports, Windows Vista Home Premium Service Pack 2 32-bit.  I've tried numerous times using device manager and directing to the Drivers folder where the inf file is located and continuously get the following message:
"Windows found driversoftware for your device but encountered an error while attempting to install it.
Arduino Uno
The system cannot find the file specified."
I've searched the forum here but haven't found any clear solution or why exactly some Vista users are able to install while others are not.  Has anyone been able to resolve this problem?
pluggy
XP has a bug installing inf files under certain circumstances, its possible it made its way into Vista as well : http://forums.techguy.org/windows-xp/235959-cannot-find-file-specified-during.html
http://pluggy.is-a-geek.com/index.html
bkbradley
Thanks, I've created the RunOnce registry key but it made no difference. Admittedly, this is above my knowledge level so I'm assuming I did so correctly. I created the key, which appears as a folder in the specified directory, which contains a REG_SZ Default file. Am I missing anything?
pluggy
The REG_SZ key is there by default in XP, its probably the case in Vista too.  I don't have Vista here to check it on.
