I’m new in this forum, also using an arduino, but i can see the potential of it. And i’m getting really excited
I would like to build a tool for my work, to improve our productivity.
Basically, we need to put some items back to stock, and to do so we need to sort them.
On each item is a barcode (to identify it), and each item has a specific location where it needs to go.
Currently, we do it « manually » : we scan an item with excel, it shows us the box number where it belongs, we find the box and we put it inside.
I would like to have the see the box where it belongs directly, without having to look for it all the time.
My idea is to scan each item, and a light will switch on over the corresponding box where to put it.
I would like to build it with excel/vba, as all data of items and boxes are in there, and then use an arduino to get the info from excel and switch on the correct light.
I will need about 40-50 lights, to switch on one by one (never more than 1 at a time).
Do you know how i could do this ?
I could see a lot of idea on the different forums, but didn’t manage to find the right one.
You’re right, « sorting » sounds better than « sortation ». I’m french, so English is not my best
I’ve checked on internet, and found a few videos about both concepts.
I’ll check how i can adapt it for my purpose.
But i’ve seen that i need to use a specific program to use the led’s, when i would need to control them via excel and vba.
Will that be possible ? And if yes, would you have some tipps ?
You're right, « sorting » sounds better than « sortation ». I'm french, so English is not my best
well your English is better than my French
I would agree with Paul in reply #2, use a WS2812b strip, you can get individual ones on small PCBs. Then all you need is to pass that number to the Arduino and have it light up just that LED number.
For a vba script running in an excel sheet to communicate with the Arduino, the script must be able to send or print characters to a serial port. It must also be able to identify which serial port the Arduino is connected to. This could perhaps be done by the user entering or selecting the port in a drop-down menu or simply by entering its name in a cell on the spreadsheet. There is no guarantee that the Arduino will always appear as the same com port each time it is plugged in.
Yes, the idea of the laser to look for books is the same than the led’s to light to put items in box.
Unfortunately, i didn’t find any code in there, on how to transfer the data from the computer to the Arduino.
I’ll need to look more, to find some help on it.
I’ll continue to post on this forum to update you on my researches
That’s really good to know.
It would actually be a list of about 7000 barcodes, to light up those 40-50 led’s (several barcodes can light the same light).
Would that be something that the arduino could manage without excel ?
Because then, i would transfer the data once a day for example, to upload the list in the arduino. It would be a easy table, with 3 columns : one for the barcode, one for the light to switch on.
I started to received the pieces to build the arduino with the lights
After a few weeks, i finally figured out how to connect the components, and how to write the code for the arduino. I used a Arduino nano, a 330 ohm resistance and the ws2812b. No need of additionnal power supply, the usb linked to the arduino is enough.
I need to find how to share pictures.
But i’m still missing the connexion between Excel VBA and the Arduino.
I want that my excel sheet is sending an information to the arduino (which led to light on) and this led will turn on. But what i’ve found on the internet was only for Visual Basic, and not working with VBA in Excel.
Would somebody have a piece of code i could re-use for that ?
I found actually something today on the Internet, which is the cod written by David M. Hitchner called "ModComm".
It should actually work for my purpose.
Here is the link for those interested : Perform Serial Port Communication from VB
Nevertheless, when i use it, i declare the variable strdata as string and set it as "5" (if i want for example to switch on the led number 5), and then in the arduino i write the following code :
So the variable "value" in the arduino should be the same that the variable "strdata" in VBA (so 5).
But no led is switching on, when i thought led number 5 would work.
It's hard to say because you did not post the VBA code. (And by the way you did not post the Arduino code correctly), but I would say that "5" is not the same value as 5.
