Topic: Resources for wire management? (Read 1 time) previous topic - next topic
falexandru
@Allanhurst
DEpends on the inspiration. I once gave kids white sandpaper and some licked it believing is in sugar. :-)). Next time I gave them a lack one so nobody licked it. ;-).
allanhurst
In the 19th century people used to drink metallic mercury to 'cure' syphillis. Not sure that was a good idea.....
Allan
larryd
Quote
Do not take them to a white sand beach!
No technical PMs.
The last thing you did is where you should start looking.
falexandru
falexandru
From what I found yesterday, the connector's world is of Jupiterian dimension.
The various connector;s names are a matter of inspiration, as far I could see in the hardware stores. Could be some standard names, I do not know - Thank you for any resource - glossary!
In the attached photo you can see the most interesting ones I brought.
Notes:
a) the "morsettes" - individual 2 ends connectors, linked together in stripes - looks very versatile, like an unidimensional breadboard
b) the bus bars - 2 types: double and simple - heavy but easy to mount by screws
c) the very small: i. 4+1 push-in (permanent) and ii. 4+1 lever-operated - these are impossible to mount - I am planning to tinker them.
The wire nuts I did not find on site, I have to order them on-line.
pert
falexandru's picture:
I'm surprised you didn't find the wire nuts. That's a very common item you'll find in any hardware here in the US. But really I don't think wire nuts are very useful for your project. They have their applications but in this case I think you want things that can be mounted flat to a board to make all the connections very clear instead of a jumble of wires hanging free in the air.
If you like the breadboard style of connection and want an extra bus strip then you should note that the ones on the white breadboards are removable. They're just attached by dovetail joint sort of plastic tabs and the adhesive backing so you can just cut the backing with a knife and detach the bus from the rest of the breadboard.
falexandru
Wire nuts may be excellent for kids - 8-9 years old. I teach them tail -mounting :-)). Maybe not so useful for my device, you are right.
Myself I never saw one wire nut. :-). I read they are quite common in USA.
Thank you very much for reminding me about the detachable strips! Excellent idea!
pert
OK, I was thinking about the wire nuts being used in a project that was simply a educational display rather than something that the children will actually be working with. I agree the wire nuts could be useful in that context. I'm not sure whether they are better or worse than a breadboard for that usage. The wire nuts can be a little tricky because you need approximately the right size for the number and gauge of the wires they are used on. If the wire nut is too big then it will just fall right off. If it's too small then it either won't engage the threads or else it only grabs the portion of the wires that are sticking up farther than the others and so doesn't provide a good connection. The benefit is they are larger than the little holes on the breadboard and it's very obvious that all the wires going into the wire nut are being connected together, which is not so much the case for someone who is new to a breadboard.
Other than the springs on my RadioShack "100 in 1" kit, I did all my electrical connections by twisting wires together when I was a kid but never had the wire nuts to make the connection secure.
TomGeorge
If you are thinking of making a more permanent/stable version of the project you described/showed at the start of this thread, then seriously think of soldering and vero or project board, the connectors you are looking at are to big and unnecessary for your electronics project, not an electrical project.
Like these;
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
falexandru
@pert
I dont know anything about wire nuts. Do you mean that their size is proportional to the number of wires? Looks logical, but the only reference I found was about the diameter of the wire.
At the moment I am not decided what to use and how.
At the Arduino day I will display the project and discuss with kids -that is for sure. It would be nice to have them work on few connections as well.
@TomGeorge
Your suggestion made me thinking to a second stage of the project with kids - to solder. However, children Safety is quite paranoid here, hope I can find a way. Maybe I will combine soldering and cold connection.
The firs board is very uncommon here. Does it have a particular name?
Myself, I use the Arduino as a learning tool. I found that many kids do not like at all the small parts. That includes the Arduino board itself! Not to mention the wires and connections.
You may compare with the Lego World: the Lego bricks for small children are much bigger than the Lego bricks for teenagers and adults.
But even so, apart from soldering and common breadboards (in three basic versions) there is not so many items suitable for kids.
Perf boards for soldering is an exiting subject - thank you for bringing it in!
MarkT
There are also kids joking about "getting electrocuted". One told me that it was electrocuted by 3V piles I gave him. I said that he must throw away the  smartphone, because it also runs on electric piles as well.:-) . He did not :-).
One really serious safety issue with low voltages and young children is swallowing button cells - this is
extremely dangerous and life-threatening, not just from choking hazard but the corrosion of the gut wall
by electrolysis leading to internal haemorhage.  Suspected swallowing of such a battery by a small child is
a full medical emergency.
falexandru
@MarkT
I agree. I only use AA (preferable) or AAA piles with kids. Never button cells.
pert
This is a cutaway diagram of a wire nut:
There is a plastic housing with a hollow conical metal insert that is threaded on the inner surface. The wire nut is used to hold the stripped ends of two or more wires in tight contact with each other. You push the bundle of wires into the open end of the wire nut and then start turning the nut. The threads will engage the wires and as the wires are threaded up into the increasingly narrow metal insert they are compressed together, which holds the contact.
The maximum diameter of the bundle of wires is limited by the A dimension in the diagram.
There is another dimension not labeled in the diagram, which we shall call F. At least on some wire nuts, the metal insert does not taper all the way to a point. The inner diameter of the metal insert at the smallest point determines the minimum diameter of the bundle of wires.
The effective capacity of the wire nut is some subset of the range between A and F. You wouldn't want to use it with a bundle of diameter A or F since at A it will be very difficult to get the threads to engage the full bundle of wires and at F the nut will not exert sufficient pressure on the wire bundle to make a good connection and prevent them from being pulled out of the nut. Instead you would want to move up or down to the next size of wire nut that has a more suitable capacity range.
The diameter of the wire bundle will be determined as much by how many wires are in the bundle as by the gauge of those wires.
For safety/reliability critical applications such as mains wiring there are specific guidelines you need to follow for how many wires can be bundled in one wire nut. For temporary low voltage, low current purposes it's more a matter of what is easy to do and reasonably stable, which you will be able to quickly determine as you use them.
falexandru
pert
I'm glad if it's helpful. I'm interested to hear what your findings are regarding the use of wire nuts for teaching young children about circuits. I don't think I've ever heard of someone using that approach before. I like that it's using common standard parts that have a low price rather than some outrageously expensive lego brick sort of thing.
I've heard of teachers using that adhesive copper tape to let their students make circuits but it's really hard to make connections with that stuff without soldering so I think it's a bad idea.
