Topic: Resources for wire management? (Read 1 time) previous topic - next topic
falexandru
As soon I will put my hands on the wire nuts and use them with kids, I ll let you know. If I will not be able to procure them, I am thinking about making them.
The construction bricks adapted for electronics and "robotics" are extremely expensive, indeed.
falexandru
#31
May 01, 2018, 07:03 pm Last Edit: May 01, 2018, 07:08 pm by falexandru
The next stage of my prototype: mounted on the portable skeleton.  See photo.
The approach to wire management was to group the components on separate mini breadboards (as shown in the previous table-mounted circuit), according to their function, in three sectors, in my case:
a) Power Sector - objects: source 3.7 LiIon 18650;  DC-DC (3.7 tp 5V)
b) Processing Sector - objects : Arduino nano; LCD 1602 I2C
c) Sensors Sector - objects : logical level translator, DHT22; BMP280
Components are defined as objects and their terminals are marked to the local line (within its sector) each one use.
Each sector has its own local lines:
Power lines:
1) GND
2) 3.3 V (if needed)
3) 5 V
Data lines:
4) I2C (2wires)
5) Digital
More Digital and Analog local lines can be added.
Each local line is connected to the others in the rest of the sectors.
In this way each sector can be reviewed and checked separately. There is no need for complex diagrams because each sector can only comprise few components.
I found this way as being rewarding in its simplicity.
The diagram drawn according to this concept (which I will post shortly) depicts only local lines and terminals notation.
The only problem is that this structured way of wiring needs more jumpers than the usual one.
If the circuit has to be enhanced this can be done either:
a) by adding more sectors - to the point the Board capacity is reached
b) by adding more processing units in a slave-master configuration
When translating to the perf (which I will do it) then multiple small plates is more configurable than only one big.
There are still improvements to be done, like using straight wires instead of jumpers, develop an intermediary Bread board that phisically separates sectors.
I am late in my project because the supplier changed the LCDs I used so I have to re-code.
Question is: is somebody aware about alternative ways to draw the circuits apart form the well-known international symbol one?
falexandru
And  here you have the structured block diagram.
It is very simple: each sector has its own internal physical lines - as described in the previous post.
From one sector to another, only one wire can pass for each individual internal line. In other words, if there is only one digital wire from the sensor, it cant pass directly to the sector 1 - it shall join the internal data line first. Then, from internal data line one wire pass to sector 1.
At a first sight it looks like excessive use of wires. But the advantages are great when the circuit is tested and when it is extended - either by more objects in one sector or by more sectors.
It is also very clear whether all components share the same ground and are connected correctly to their power or data line.
falexandru
I was unable to find here wire-nuts. I can either find an European provider (which is somehow excessive for a 2 dollar purchase) or attempt manufacturing (DiY) them - somehow- any suggestion welcomed!
pert
Why not just order them online? If you would have done so when the topic first came up they would have already been delivered, even from China.
For other suggestions, it might be helpful if you said where you're located.
falexandru
In my view it is a waste of money to order a 2 USD merchandise that is going to cost 50 USD delivery (or even 20 USD).
Another point is that I may need different types in different quantities, which may result in repeated orders, adding up delivery costs and waiting times.
pert
Here in the US I can buy bags of wire nuts on eBay or Aliexpress for as little as $0.50 for 10 pcs and have them shipped to me for free from China. You can buy collections of assorted sizes or just a specific size. Is the shipping really so expensive where you're at?
ted
wire-nuts are for electrical work not for electronics
ted
falexandru
@ Ted I know. But I want to use them for kids. I leave the wires "on air" like in the old times. Currently, I just teach kids to twist the wires by hand. To many times this operation fails because of wires sliding.
Those wire-nuts would be excellent to replace the twisting. But I want to check this before buying in bigger volumes.
For kids I want big things :-)).
I also invented a sort of tool that twist thin wires around the components terminal. But this is to small for kids :-(.
Thanks for photo!
falexandru
The push-wire terminal connectors (I think they are called WAGO)  I found in the electrical products sector in the hardware store are not designed for high voltage, as far as I understand.
They are very nice to click all wires together but require to much force to operate, exceeding what a kid can do. Still, nice piece of engineering.
I do not know whether WAGO rail mounted connectors are small and cheap enough to use for small circuits.
falexandru
https://www.intel.com/content/dam/www/public/us/en/documents/presentation/low-temperature-soldering-introduction.pdf
This is about low temperature soldering. Something 25-47 C as far as I understand.
That may fit work with kids.
But I have no idea about regular (common, hobby) use of this technology. Impressive, though.
ted
#42
May 21, 2018, 11:22 pm Last Edit: May 21, 2018, 11:25 pm by ted
the smalest -71B Gray Wire Nut Connector -they are good for above cable, the big will not  stay on connected wires
ted
For thin wires - small wire splice connectors
ted
Kids and high voltage ?, safe voltage is 24V
