Topic: code work fine on usb power or external regulated power but not on battery. (Read 881 times) previous topic - next topic
developeruspcase
Hey,
I am working on some iot project that need to transmit data to server after 30 secs. My code works fine for more than hour while connect to usb or external power supply at 4.1
But my code stop working randomly after 10-30mins  when just battery is connected, i have tested both 1000mah and 2000mah 3.7 lipo battery.
I am using simple gsm client sketch to upload to server using POST request.
Any solution?
smgs
Can you share your sketch with us, if you are not putting your device into a low power mode or turning it off then it may just be your battery running flat? Easiest way I can think to check that would be to read the battery voltage as part of your sketch and see if it goes down over the 1 hour it works for when on battery only.
developeruspcase
I am not putting device into low power mode, however i am keeping a check over battery and battery remain over 4v. battery running flat is not a problem.
suggest me some way to trace the problem as the problem doesn't occur while connected to serial.
smgs
Hi developeruspcase,
The basic included sketch with the MKR GSM 1400, which I've used to upload data to a website, runs once only, and then includes a for loop which ensures that the device does nothing after running once.
How has your sketch been configured to run multiple times?
Are you able to give us some help in troubleshooting your sketch by either sharing the sketch you use and the output from it if it does output to standard out. If you can share it, please use the Included code format markup to make it easier to read.
That's probably the best way of troubleshooting is to have the serial monitor open and include some print lines at key places within your sketch to demonstrate to yourself what your sketch is doing or running when it stops working.
ballscrewbob
smgs is correct.
We would need to see the sketch itself to be able to diagnose what you are seeing.
If there is a "while serial" statement (or similar) that would possibly cause issues as it waits for the USB/communications to be connected before it will continue.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
