Topic: Mipi Connector (Read 554 times) previous topic - next topic
a2retro
Hi Dario, From the pictures one would assume that if you are using the pci-e connector that you would not be able to use the mipi connector at the same time? Is that correct?
DarioPennisi
Actually mipi connector can be used when board is plugged in mini PCIe as the ffc cable nicely rests on top of the female connector. It becomes just a bit harder to fit the ffc in but you can insert it before plugging the board in the host.
