Topic: MKRMotorCarrierr (Read 2974 times) previous topic - next topic
ilich262
I am trying to run Motor_test.ino and Motor_test_ encoder.ino. (Please see attached files)  They are not working. I got the message bellow.
I also have tried some troubleshooting..I checked the battery.. ... I even updated the MKRMotorCarrierr firmware uploading the example, Flasher. I also tried to run the Blink example and it's not working. When I removed the carrier from the MKR1000, "Blink" works. I don't know what's the problem with the carrier.
Please advise
WARNING: Category 'I/o' in library MKRMotorCarrier is not valid. Setting to 'Uncategorized'
Build options changed, rebuilding all
Sketch uses 22024 bytes (8%) of program storage space. Maximum is 262144 bytes.
Atmel SMART device 0x10010005 found
Device       : ATSAMD21G18A
Chip ID      : 10010005
Version      : v2.0 [Arduino:XYZ] Dec 20 2016 15:36:43
Address      : 8192
Pages        : 3968
Page Size    : 64 bytes
Total Size   : 248KB
Planes       : 1
Lock Regions : 16
Locked       : none
Security     : false
Boot Flash   : true
BOD          : true
BOR          : true
Arduino      : FAST_CHIP_ERASE
Arduino      : FAST_MULTI_PAGE_WRITE
Arduino      : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 0.820 seconds
Write 22328 bytes to flash (349 pages)
[=====                         ] 18% (64/349 pages)
[===========                   ] 36% (128/349 pages)
[================              ] 55% (192/349 pages)
[======================        ] 73% (256/349 pages)
[===========================   ] 91% (320/349 pages)
[==============================] 100% (349/349 pages)
done in 0.140 seconds
Verify 22328 bytes of flash with checksum.
Verify successful
done in 0.018 seconds
CPU reset.
pert
What exactly do you mean by "it's not working"?
While this warning itself doesn't cause any problems, it does indicate you're using an outdated version of the MKRMotorCarrier library. Please do this to update to the latest release:
  • Sketch > Include Library > Manage Libraries...
  • Wait for download to finish
  • In the "Filter your search..." box, type "MKRMotorCarrier".
  • Click on "MKRMotorCarrier by Arduino".
  • Click "Update".
  • Wait for update to finish.
  • Click "Close".
  • Upload your sketch again.
