Topic: Successfully sending MIDI CC over Bluetooth? (Not note on/off) (Read 823 times) previous topic - next topic
Monoth
Hi there,
I recently got a few adafruit bluefruit feather LE boards as I read that they can send MIDI over USB:
https://learn.adafruit.com/adafruit-feather-32u4-bluefruit-le/overview
I tried one and yes indeed, it sure can. However, it only seems to be able to send note values and not continuous control messages for pots/sliders etc..
The only examples I see of midi being sent are in these examples, and they only concern note on/off:
https://learn.adafruit.com/bluetooth-le-midi-controller/software
https://learn.adafruit.com/wireless-untztrument-using-ble-midi/overview-uniontownlabs
I have already posted on the Adafruit forum and no response so I'm just wondering if anyone on here has found a way to send CC over bluetooth?
p.s. if this post is not permitted as it's not an Arduino product then my apologies.
Thank you :)
PieterP
CC messages are almost identical to note messages. Just replace the 0x8 or 0x9 status nibble (for note off and note on resp.) with the 0xB status nibble for CC. Data 1 is the controller number instead of the note number, and data 2 is the CC value instead of the velocity.
Pieter
Monoth
Thanks so much for your response. So, if I understand you correctly, the setup would not be like this?:
  // send note on
  midi.send(0x90, current_note, 0x64);
  // send note off
  midi.send(0x80, current_note, 0x64);
  // Send cc instead
  midi.send(0xB, contoller_number, ccvalue);
"midi.send" is the function used in the BLE library for the Adafruit controller
PieterP
Almost, 0xB is the high nibble of the status byte. The low nibble is the channel (0x0 - 0xF for channels 1 - 16 respectively). So if you want to send on channel 1, you use 0xB0 as status byte, 0xB1 for channel 2, 0xB2 for channel 3, etc.
Monoth
Great. Thanks so much for clearing that up:) I was used to using the midi serial midi library which has separate functions for notes and cc's. That's why I was confused.
I'll test this out asap and report back!
wheels1758
I am not the OP but I am having an issue sending CC messages using the adafruit blemidi library. I was able to successfully send a CC signal, but it is hit and miss. If I print my Cc value to the serial monitor, I can see that it is changing, so the hardware setup seems to be fine, but it only occasionally sends the signal (testing by controlling loopcommunity PRIME via midimittr). Is there a way to flush the midi commands to ensure they actually send?
