Topic: Linnk serproxy with mingw (Read 1 time) previous topic - next topic
epanda
I have source code of serproxy 1.2.0 and mingw. I don't have visual studio.
Could Somebody help me to link serproxy under Win Vista with mingw only ?
thank you
robtillaart
you can download Visual Studio Express for free - http://www.microsoft.com/express/
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
epanda
would like to update unix makefile in order to avoid visual studio
epanda
Visual Studio Express 2010 does not happen to convert dsp file.
I switch to mingw compilation and modified the makefile like that in order to be compatible with mingw:
Code: [Select]
# File: Linux serproxy makefile
# (C)1999 Stefano Busti
VERSION = `cat VERSION`
INC = \
  C:/MinGW/msys/1.0/include
SRCS = \
  main.c sio.c sock.c thread.c vlist.c cfglib.c config.c string.c \
  pipe.c error.c
OBJS = \
  main.o sio.o sock.o thread.o vlist.o cfglib.o config.o string.o \
  pipe.c error.c
CC = gcc
ifdef DEBUG
CFLAGS = -I$(INC) -Wall -g -D__UNIX__ -DDEBUG
CFLAGS = -I$(INC) -Wall -O2 -fomit-frame-pointer -D__UNIX__
endif
ifdef USE_EF
LIBS= -lpthread -lefence
LIBS= -lpthread
endif
# Build the program
serproxy: $(SRCS) $(OBJS)
$(CC) $(CFLAGS)  -o serproxy $(OBJS) $(LDFLAGS) $(LIBS)
install: serproxy
cp -f serproxy c:/temp
clean:
del /F *.o
realclean:
del /F *.o serproxy *.gz *.zip
dep:
makedepend -Y -- $(CFLAGS) -- $(SRCS) 2&>/dev/null
# DO NOT DELETE
main.o: sio.h sock.h pipe.h thread.h vlist.h cfglib.h config.h error.h
sio.o: sio.h
sock.o: sock.h
thread.o: thread.h
vlist.o: vlist.h
cfglib.o: cfglib.h
config.o: config.h cfglib.h string.h
string.o: string.h
pipe.o: pipe.h sio.h sock.h thread.h
error.o: error.h
and I got this error:
Quote
|| gcc -IC:/MinGW/msys/1.0/include -Wall -O2 -fomit-frame-pointer -D__UNIX__   -c -o main.o main.c
In file included from c:\mingw\bin\..\lib\gcc\mingw32\4.5.0\..\..\..\..\include\windows.h|98| 0,
||                  from sio.h:21,
||                  from main.c:24:
c:\mingw\bin\..\lib\gcc\mingw32\4.5.0\..\..\..\..\include\winsock2.h|103 col 2| warning: #warning "fd_set and associated macros have been defined in sys/types.      This may cause runtime problems with W32 sockets"
c:\mingw\bin\..\lib\gcc\mingw32\4.5.0\..\..\..\..\include\winsock2.h|109 col 8| error: redefinition of 'struct timeval'
C:\MinGW\msys\1.0\include\sys\time.h|16 col 8| note: originally defined here
In file included from thread.h|12| 0,
||                  from pipe.h:6,
||                  from main.c:26:
C:\MinGW\msys\1.0\include\pthread.h|71 col 42| error: expected ')' before '*' token
Can somebody help me ?
robtillaart
You might try to remove the INC directory as that may cause a conflict (redefinitions)
interesting read - http://www.gnu.org/software/make/manual/make.html - not for the faint of heart ;)
Rob Tillaart
