Topic: SOLVED: difficulty getting a void command to work  (Read 923 times) previous topic - next topic
rcvolley
Sep 28, 2018, 10:30 pm Last Edit: Sep 29, 2018, 01:22 am by rcvolley
this code successfully allows me to control a PWM from a web page the part I'm having trouble with is the test command part its supposed to execute the test command sequence when I insert the word test into the correct place in the IP address but all I get when I enter it is a blank page I'm wondering what I'm missing because I can't tell what's going wrong.
Code: [Select]
#include <Bridge.h>
#include <BridgeServer.h>
#include <BridgeClient.h>
#include <Console.h>
BridgeServer server;
int value;
int pin;
int onoff;
int value2;
int pin2;
int onoff2;
  Bridge.begin();
  server.listenOnLocalhost();
  server.begin();
  Console.begin();
  BridgeClient client = server.accept();
  if (client) {
    process(client);
    client.stop();
  analogWrite(pin, value);
  analogWrite(pin2, value2);
  if (onoff == 1) {
    digitalWrite (12, HIGH);
  else {
    digitalWrite (12, LOW);
  if (onoff2 == 1) {
    digitalWrite (2, HIGH);
  else {
    digitalWrite (2, LOW);
void process(BridgeClient client) {
  String command = client.readStringUntil('/');
  if (command == "analog") {
    analogCommand(client);
  if (command == "test") {
    testCommand(client);
void analogCommand(BridgeClient client) {
  pin = client.parseInt();
  if (client.read() == '/') {
    onoff = client.parseInt();
      value = client.parseInt();
      client.println(value);
      if (value > 255) {
        client.println("#Error  PWM > 255#");
        analogWrite(pin, 0);
        pin2 = client.parseInt();
          onoff2 = client.parseInt();
            value2 = client.parseInt();
  client.println("155.101.101.52/arduino/analog/pin/on or off/ PWM value/PIn for second high voltage/on or off for second battery/second PWM value");
void testCommand(BridgeClient client) {
  client.println("running test");
  client.println(pin);
  client.print(":");
  client.print(value);
  client.println(pin2);
  client.print(":");
  client.print(value2);
rcvolley
I figured it out you have to put
pin3 = client.parseInt(); in front of
and then in the web address, you have to put a / and then add a number to the end to make it work correctly.
