Topic: Variable not declared in scope (Read 1 time) previous topic - next topic
SRaja001
I am writing this to find the pinout to a 4 by 3 keypad.  I am very new to arduino so I am not exactly sure what is wrong.
//keypad Pinout
int val1 = 0;
int val2 = 0;
int val3 = 0;
int val4 = 0;
int val5 = 0;
int val6 = 0;
int val7 = 0;
  pinMode(1,INPUT);
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  pinMode(4,INPUT);
  pinMode(5,INPUT);
  pinMode(6,INPUT);
  pinMode(7,INPUT);
  va11 = digitalRead(1);
  va12 = digitalRead(2);
  va13 = digitalRead(3);
  va14 = digitalRead(4);
  va15 = digitalRead(5);
  va16 = digitalRead(6);
  va17 = digitalRead(7);
  if ((val1==HIGH) || (val2==HIGH) || (val3==HIGH) || (val4==HIGH) || (val5==HIGH) || (val6==HIGH) || (val7==HIGH))
  Serial.println(val1,val2,val3,val4,val5,val6,val7);
This is the error message I get:
sketch_mar30a.cpp: In function 'void loop()':
sketch_mar30a:24: error: 'va11' was not declared in this scope
sketch_mar30a:25: error: 'va12' was not declared in this scope
sketch_mar30a:26: error: 'va13' was not declared in this scope
sketch_mar30a:27: error: 'va14' was not declared in this scope
sketch_mar30a:28: error: 'va15' was not declared in this scope
sketch_mar30a:29: error: 'va16' was not declared in this scope
sketch_mar30a:30: error: 'va17' was not declared in this scope
sketch_mar30a:33: error: no matching function for call to 'HardwareSerial::println(int&, int&, int&, int&, int&, int&, int&)'
C:\Users\Sree\Desktop\arduino-0022\hardware\arduino\cores\arduino/Print.h:54: note: candidates are: void Print::println(const String&)
C:\Users\Sree\Desktop\arduino-0022\hardware\arduino\cores\arduino/Print.h:55: note:                 void Print::println(const char*)
C:\Users\Sree\Desktop\arduino-0022\hardware\arduino\cores\arduino/Print.h:56: note:                 void Print::println(char, int)
C:\Users\Sree\Desktop\arduino-0022\hardware\arduino\cores\arduino/Print.h:57: note:                 void Print::println(unsigned char, int)
C:\Users\Sree\Desktop\arduino-0022\hardware\arduino\cores\arduino/Print.h:58: note:                 void Print::println(int, int)
C:\Users\Sree\Desktop\arduino-0022\hardware\arduino\cores\arduino/Print.h:59: note:                 void Print::println(unsigned int, int)
C:\Users\Sree\Desktop\arduino-0022\hardware\arduino\cores\arduino/Print.h:60: note:                 void Print::println(long int, int)
C:\Users\Sree\Desktop\arduino-0022\hardware\arduino\cores\arduino/Print.h:61: note:                 void Print::println(long unsigned int, int)
C:\Users\Sree\Desktop\arduino-0022\hardware\arduino\cores\arduino/Print.h:62: note:                 void Print::println(double, int)
C:\Users\Sree\Desktop\arduino-0022\hardware\arduino\cores\arduino/Print.h:63: note:                 void Print::println()
retrolefty
#1
Mar 31, 2011, 12:28 am Last Edit: Mar 31, 2011, 12:30 am by retrolefty Reason: 1
Change:
Code: [Select]
To:
Quote
val1 = digitalRead(1);
 val2 = digitalRead(2);
 val3 = digitalRead(3);
 val4 = digitalRead(4);
 val5 = digitalRead(5);
 val6 = digitalRead(6);
 val7 = digitalRead(7);
Yes, the C/C++ compiler is really that picky. It works on what you type in, not what you meant to type in.  :D
Lefty
MarkT
In other words spell 'val' with a letter l not a digit 1...
Also you can't use print or println with lots of values - the print library has to be tiny.
You can be much more concise with the boolean expression in the 'if':
Code: [Select]
Code: [Select]
  if (val1 || val2 || val3 || val4 || val5 || val6 || val7)
HIGH is treated as true and LOW as false.
PaulS
Code: [Select]
  pinMode(1,INPUT);
You can't use pin 1 and Serial at the same time, either.
