Topic: Why isn't my LED fading? (Read 1 time) previous topic - next topic
Jxmorris12
I'm using a Shiftbrite. My first time writing code!   :) Any improvements? Also... why doesn't it work? I tried to copy the sample LED fade as best as I could.
Code: [Select]
int datapin  = 10; // DI
int latchpin = 11; // LI
int enablepin = 12; // EI
int clockpin = 13; // CI
unsigned long CommandPacket;
int Command;
int Blue = 1023; // Maximum Blue
int Red = 1023; // Maximmum Red
int Green = 1023; // Maximum Green
int Fade = 5;
   pinMode(datapin, OUTPUT);
   pinMode(latchpin, OUTPUT);
   pinMode(enablepin, OUTPUT);
   pinMode(clockpin, OUTPUT);
   digitalWrite(latchpin, LOW);
   digitalWrite(enablepin, LOW);
void SendPacket() {
   CommandPacket = Command & B11;
   CommandPacket = (CommandPacket << 10)  | (Blue & 1023);
   CommandPacket = (CommandPacket << 10)  | (Red & 1023);
   CommandPacket = (CommandPacket << 10)  | (Green & 1023);
   shiftOut(datapin, clockpin, MSBFIRST, CommandPacket >> 24);
   shiftOut(datapin, clockpin, MSBFIRST, CommandPacket >> 16);
   shiftOut(datapin, clockpin, MSBFIRST, CommandPacket >> 8);
   shiftOut(datapin, clockpin, MSBFIRST, CommandPacket);
   delay(1); // adjustment may be necessary depending on chain length
   digitalWrite(latchpin,HIGH); // latch data into registers
   digitalWrite(latchpin,LOW);
   Command = B00;
   Blue = Blue - Fade;
   delay (10);
   Fade = Fade + 5;
   if (Blue = 0);
      Fade = -Fade;
Thanks!
Jack
pedroferrer
Hi
Where are you calling 'void SendPacket' !?
Best regards
Pedro Ferrer
Jxmorris12
Hi! Can you explain that a little bit more? Or maybe provide some sample code? I'm new to coding.. and electronics in general. Thanks :)
Jack
pedroferrer
Hi Jack
On loop() procedure, you should call SendPacket()
void loop(){
      SendPacket();
Best regards
Pedro Ferrer
Jxmorris12
Thanks, Pedro. It still isn't working for me. Did I put it in the wrong place?
Code: [Select]
unsigned long Packet;
int Command;
int Blue = 0; // Maximum Blue
int Fade = 50;
void SendPacket() {
   Packet = (Packet << 10)  | (Blue & 1023);
   Packet = (Packet << 10)  | (Red & 1023);
   Packet = (Packet << 10)  | (Green & 1023);
   shiftOut(datapin, clockpin, MSBFIRST, Packet >> 24);
   shiftOut(datapin, clockpin, MSBFIRST, Packet >> 16);
   shiftOut(datapin, clockpin, MSBFIRST, Packet >> 8);
   shiftOut(datapin, clockpin, MSBFIRST, Packet);
   SendPacket();
   Command = B00;
   Blue = Blue + Fade;
   Command = B00;
   if (Blue = 0);
      Fade = -Fade;
   delay (10);
pedroferrer
Hi
Your 'Blue' variable has to be placed on
analogWrite(IO_Intended, Blue);
Eg: IO_Intended should be between 1 and 13 (D1, D2...) on Mega...
Best regards
Pedro Ferrer
Jxmorris12
I am so confused. I used the wrong output pins?
pedroferrer
Hi
analogWrite enables PWM signal... that way you can fade the leds...
digitalwrite is like ON/OFF... LOW/HIGH state...
Best regards
Pedro Ferrer
Jxmorris12
Oh! Got it, thanks! From my code, which pin do I want to set?
johnwasser
Your code is close.  Since your are using the 'shiftbrite', ignore the PWM suggestions.
Code: [Select]
   Command = B00;
   SendPacket();
   Blue = Blue - Fade;  // same as  Blue -= Fade;
    if (Blue < 1  || Blue > 1023)
       Blue += Fade;  // Step back one
       Fade = -Fade;  // Reverse direction of fade
   Fade = Fade + 5;  // Increase rate of fade, decrease rate of brightening.
    delay (10);
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
