Topic: expected unqualified-id before if (Read 1 time) previous topic - next topic
Nater
I am writing a program for a simple line following robot and keep getting the same error message.  I am new to arduino and dont understand the error messages.  Any help would be aprecciated.
Heres the code.
Code: [Select]
// Using Arduino uno
// Pin definitions - attaches a variable to a pin.
const int RightMotor = 8; // This pin is used to enable or disable the Right motor. Connected to the base of an NPN transistor.
const int LeftMotor = 7; // This pin is used to enable or disable the Left motor. Connected to the base of an NPN transistor.
const int Sensor = A0; // This pin is used to read the value of the Right Sensor.
// Variable definitions
int Sensorv; //ldr sensor
// the setup() method runs once when the program is run. When the
// Arduino is reset, the setup() will be executed once again.
pinMode(LeftMotor, OUTPUT); // Defines this pin as an output. The Arduino will write values to this pin.
pinMode(RightMotor, OUTPUT); // Defines this pin as an output. The Arduino will write values to this pin.
pinMode(Sensor, OUTPUT);
Serial.begin(9600); // Enables a serial connection through the Arduino to either USB or UART (pins 0&1). Note that the baud rate is set to 9600
Serial.println(" \nBeginning Light Seeking Behavior"); // Placed at the very end of void Setup() so that it is runs once, right before the void Loop()
// the loop() method runs over and over again,
// as long as the Arduino has power
Sensorv = 1023 - analogRead(Sensor); // This reads the value of the sensor, then saves it to the corresponding integer.
// This section of the sketch is used to print the values of the
// sensors through Serial to the computer. Useful for determining
// if the sensors are working and if the code is also functioning properly.
Serial.print("Left Sensor = "); // Prints the text inside the quotes.
Serial.print(Sensor); // Prints the value of the Left Sensor.
Serial.print("\t"); // Prints a tab (space).
// This section of the sketch is what actually interperets the data and then runs the motors accordingly.
if (Sensorv < 6 ) { //turn right
digitalWrite(RightMotor, LOW); // This is used to turn right. Notice the
digitalWrite(LeftMotor, HIGH; // opposite motor runs to turn right.
Serial.println("right"); //print to moniter
if (Sensorv > 8 ) { //turn left
digitalWrite(RightMotor, HIGH); // This is used to turn left. Notice the
digitalWrite(LeftMotor, LOW);   // opposite motor runs to turn left.
Serial.println("left"); //print to monitor
Serial.print("\n");
retrolefty
Simple typing errors, see blue text below. It now complies without errors, but I don't say it does what you wish yet, that's for you to test.
Quote
                // // remove this }
digitalWrite(LeftMotor, HIGH); // missing )  opposite motor runs to turn right.[/color]
Serial.print("\n");
Nater
