Topic: PWM phase correct 10 bit with 2 timers (timer0 and timer 2). (Read 777 times) previous topic - next topic
MichaelBagieta
Hi, i need to use pwm control for 4 devices. I've used phase correct pwm mode from timer/counter1 to get low frequency (~8Hz). But unfortunately it is possible only for timer/counter 1, which has 2 outputs. I need to get this frequency for another 2 devices. Is there any possibility to make 10 bit PWM phase correct control by using 2 x 8 bits timers (timer 0 and timer 1)?
GolamMostafa
The following diagram says that every TC of ATmega328P has two programmable PWM channels.
DrAzzy
No, you cant get 10-bit hardware pwm with an atmega328 on more than 2 channels. You cant turn two 8 bit timers into a 10-bit timer, not if you want hardware pwm. Howver you can:
Use a different chip with 2 16-bit timers (attiny841 (use my core), atmega328pb (use minicore), atmega 1284p (use mightycore), atmega2560 (arduino mega), or atmega2561(use megacore)
The smaller flash versions of above will also work.
At only 8hz, you might be able to do it in software
Or you could use a non-AVR chip
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
ron_sutherland
ATmega328pb does some odd things with the pwm from Timer3, and Timer4. I have started to look more at ATmega324pb, which has three 16bit timers (Timer1, Timer3, Timer4) with A and B output compare registers.
if ATmega324pb then https://github.com/MCUdude/MightyCore/
if ATmega328pb then https://github.com/MCUdude/MiniCore/
my projects: https://github.com/epccs
DrAzzy
It puts oc3b and oc4b on the same pin, so there is one fewer pwm pins available - but thats the only "weird" thing it does with the pwm. Unless you enable the oc modulation mode, of course. But iirc the atmega2560 has the same thing
sterretje
Or a 32U4 based board.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
