Topic: different voltage reading with multimeter (Read 377 times) previous topic - next topic
JumperIQ
Hello everyone.
I am new to powering and I am facing something I can't understand it, however, I bought a multimeter called DT-830B to measure the voltage of my components, the below measurements seems to be weird to me
1) 3.7v battery when measuring it the multimeter display 4.8V
2) AC-to-DC adapter output 12v when measuring it the multimeter display up to 15V
any help will be appreciated.
jremington
#1
Oct 10, 2018, 07:18 pm Last Edit: Oct 10, 2018, 07:20 pm by jremington
Both of those values are plausible.
Measure a brand new "1.5 V" alkaline battery. I usually get between 1.56 and 1.58V on several meters.
However, Wikipedia says:
The effective zero-load voltage of a non discharged alkaline battery, however, varies from 1.50 to 1.65 V, depending on the purity of the manganese dioxide used and the contents of zinc oxide in the electrolyte.
No PM's please.
JumperIQ
well, is that me it is ok?
I measured the Arduino +5v pin and it is giving me more than 5v!
jremington
#3
Oct 10, 2018, 07:44 pm Last Edit: Oct 10, 2018, 07:45 pm by jremington
No surprises there. Components have tolerance specifications, which are stated in the component data sheet.
The 5V regulator on the Arduino might typically produce anywhere between 4.75 to 5.25V (different for each chip), which is fine.
What do you get for a brand new alkaline battery, or several of them?
No PM's please.
slipstick
It sounds like your meter is not accurate. If the 3.7V battery is a Lipo then it would probably have exploded before it actually got to 4.8V. You should never see more than 4.2V om a Lipo. As jremington says the best thing to test it with is a brand new 1.5V alkaline battery.
It would be worth checking the 9V battery in the meter. A bad battery will give all sorts of odd readings.
Steve
Wawa
+1
Some cheap DMMs give higher voltage readings when the internal battery is getting low.
One of my DMMs does.
Check if the "low batt" sign is also being displayed.
Leo..
TheNoneP
+1
Some cheap DMMs give high voltage readings
I would like to thank you all, Leo  your suggestion helped me.
