Topic: Doubt about WPA-PSK / WPA2-PSK wifi detection # arduino yun rev 2 (Read 869 times) previous topic - next topic
Greg2018
does anyone know if the arduino yun rev 2 is able to detect WPA-PSK / WPA2-PSK wifi ??
I have two wifi at home (WPA2-PSK) and when I try to configure the wifi of the arduino yun only detect the wifi of my neighbours, which I suppose are only WPA or WPA2.
I´ve tried to change the configuration of my wifi to others authentication types like Shared Key + WEP due to doesn´t admit only WPA or WPA2 (without PSK), but never find it.
So, could you anyone help me about which wifi options are able to detect the yun?
Thanks a lot !!
ballscrewbob
The WiFi is 2.4 GhZ only.
Ensure you are not trying to connect to a 5 GhZ network.
WPA2 PSK AUTH seems fine here but admittedly on an earlier YUN and a variety of other wireless boards.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Greg2018
Thanks a lot ballscrewbob, I´m happy hearing that you comment.
First of my wifi is 2.4 GhZ and the second one is 5 GhZ, so the first should be detected and I don´t know why then.
Any idea? - very debilited wifi signals of my neighbours (e.g. 27% power) are detected wihtout problem.
Checking the properties of my 2.4 GhZ signal it is "WPA2-Personal" - I thougth it was "WPA2-PSK", should it be admitted too?
Thanks again !
Greg2018
Wifi detected !!
I´ve changed the Channel of my 2.4 GhZ to 11 (it was 13 but I´ve read in other forums that sometimes give errors in some devices).
After detect my wifi and put the password into the Yun the blue led is continuos (not flicker), so I suppose the wifi is correctly detected and configured. Nevertheless, when the Yun is restarting and I connect again my computer to the wireless network (as it says) I cannot acces by using "arduino.local" (I´ve not changed the name) or "192.168.240.1" - is it usual? any idea? perhaps the firewall?
Thanks !!
ballscrewbob
Check your routers DHCP list to see if the YUN is already in there.
If it is use that IP address to get to your YUN.
Not unusual for the "LOCAL" to not always work and it is mentioned in quite a few questions.
Greg2018
Thanks for everything ballscrewbob.
I will check and I comment you for future people.
Best regards
Greg2018
It works by finding the IP ballscrewbob, fantastic!! - thanks
One more question please; I'm trying to obtain info from a device connected to the USB Type-A port (e.g. a mouse) but when I connect it, seems to do nothing (no led of the yun, no led of the mouse, etc.) -  do you know where can I find info, necessary configuration of the yun (in case the USB A port needs to activate) or any sample by here?
Thanks in advance !!
ballscrewbob
Not 100% sure but think the USB port can be accessed via the Linux side.
Some hints from Google
Greg2018
thanks @ballscrewbob
I´ll open a new topic with this theme in case anyone knows about it, due to the actual title is concerning with the wifi detection.
Thanks for all.
Regards !!
