Topic: Arduino Linux Ubuntu, arduino cant access /dev/ttyUSB0 [SOLVED] (Read 815 times) previous topic - next topic
LinaLangemark
I have Arduino 1.8.5 and Linux Ubuntu 18.04. I'm using an Arduino Uno board.
Hi, I'm very new to both Arduino and Linux, but since the board had the same problem on Windows, I thought I'd try a Linux computer.
I have basically tried doing everything the internet has told me to do so far.
This is the error message I get when I try running a simple "Blink" program.
Code: [Select]
Arduino: 1.8.5 (Linux), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "/dev/ttyUSB0": Permission denied
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
I have tried following the official guide to solve this, which is;
1. Typing this in the terminal:
Code: [Select]
ls -l /dev/ttyACM*
you will get something like:
Code: [Select]
crw-rw---- 1 root dialout 188, 0 5 apr 23.01 ttyACM0
2. Adding myself to the dialout group:
Code: [Select]
sudo usermod -a -G dialout <username>
    - I have also added myself to the tty group, uttc, and disk group, because I saw other people added themselves to those groups and it helped.
I have also tried using
Code: [Select]
sudo chmod a+rw /dev/ttyUSB0]
Code: [Select]
$ snap install arduino-mhall119 --classic
And I have tried doing
Code: [Select]
sudo -i to get temporary root acces, and then doing all of these things again.
I rebooted my computer numerous times and reinstalled Arduino twice.
Nothing has worked.
I don't know enough about this to really be sure that I did it all right. It seems like my user has access to
Code: [Select]
/dev/ttyUSB0, but my Arduino doesn't, for some reason.
So, if you have any ideas left, I would really appreciate some help.
kayel
 Hello,
 Your Arduino IDE is looking for a /dev/ttyUSB0 and you haven't got one. You have a /dev/ttyACM0.
 Open the Arduino IDE and go to the Tools menu. Click on port and change it to /dev/ttyACM0.
 Hope it works.
pert
Hopefully kayel's suggestion will resolve your problem.
If not, there have been previous reports of this type of issue being caused by using the 3rd party unofficial arduino-mhall119 Snap package. The problem was resolved after uninstalling it and then installing the official Arduino IDE, downloaded from:
http://www.arduino.cc/en/Main/Software
LinaLangemark
Hello,
 Hope it works.
The only port that Tools>Port shows is /dev/ttyUSB0, it doesn't show /dev/ttyACM0, and I can't find it under any groups in the terminal either, as if it doesn't exist.
But thank you.
kayel
 If you installed the Arduino IDE with apt-get or synaptic then you should uninstall it using the same method. I've heard the Debian-based packages are not maintained. Then follow pert's link.
 If you plug in your Arduino and type "ls /dev" you should get the "tty x" (at the end of all the "tty" stuff) that the Arduino IDE is looking for. If not, uninstall and follow pert's link.
 Never install stuff as root, if you do, it will belong to root, not you. Use sudo.
 Type "groups <yourname>" to make sure you really are in the "dialout" group
 Out of ideas for now.
LinaLangemark
#5
Jan 17, 2019, 01:22 pm Last Edit: Jan 17, 2019, 01:29 pm by LinaLangemark
I solved the problem, but thanks for the help!
I ended up having to reinstall arduino using
Code: [Select]
snap install arduino-mhall119 --classic.
LinaLangemark
Actually, the problem was solved by using the snap package, I wouldn't know why though...But thank you!
pert
That was unexpected. Well, I'm just glad it's working now!
However, you should note that the arduino-mhall119 provides an IDE version that's over a year outdated. There have been a lot of bug fixes and improvements since that time. If you ever want to enter the modern age of Arduino, consider installing the official Arduino IDE.
IjonTichyRaumpilot
When an app runs on flatpak that could cause a problem. Flatpak by default blocks all (or most) devices. By adding --device=all you get it work. See here https://stackoverflow.com/questions/41252334/accessing-serial-ports-with-an-application-runs-in-flatpak
