Topic: Reading values from a dst800 sensor which uses nmea2000 protocol (Read 394 times) previous topic - next topic
harshitnagar
How can I read the values from a DST800 sensor using arduino? It uses NMEA2000 protocol. I also have 2 MCP2515 CAN Controller Modules. I used this https://www.electronicshub.org/arduino-mcp2515-can-bus-tutorial/ tutorial to send and receive data over CAN bus. How can i receive values from my dst sensor? I was thinking about using only the receiver part of the code. Some tips and approach to solve the issue would be of great help.
Thank you
ferbolano
Hola,
Yo estoy intentando hacer lo mismo con un DST800 y creo que es necesario un micro mas poderoso como un mega, un due o teensy para soportar la librería y la velocidad de datos de transmisión.
Intenta revisar este foro:
https://forum.arduino.cc/index.php?topic=50893.0
ahí recomiendan esta librería:
https://github.com/ttlappalainen/NMEA2000
cuéntame como va tu proyecto,
saludos
Thank you
Tephe89
Hey, i have the same projet.
Did you manage to get the information on the Arduino Mega board?
