Topic: MKRFOX1200 max deepSleep period (Read 422 times) previous topic - next topic
iverona
Hello,
What's the max deepSleep period allowed on a MKRFOX1200? The function is defined as:
Code: [Select]
void deepSleep(void);
void deepSleep(uint32_t millis);
void deepSleep(int millis) {
    deepSleep((uint32_t)millis);
So I should be able to use the UINT32_MAX which is 4294967295UL, but if I try for example, to sleep for 24H:
Code: [Select]
#define WAKE_UP_INTERVAL_24H 86400000UL //24H
LowPower.deepSleep(WAKE_UP_INTERVAL_24H);
The board wakes up immediately after reset. Am I doing something wrong?
thanks!
iverona
Forgot to mention that:
Code: [Select]
#define WAKE_UP_INTERVAL_6H 21600000UL  //6H
Works. And that I've also tried casting the value to uint32_t when calling deepSleep but no difference.
