Topic: arduino nano connected to hc-sr04 error message  (Read 79 times) previous topic - next topic
Looodi2010
I keep getting an error message when I tried the code below.
const int TriggerPin = 7;      //Trig pin
const int EchoPin = 8;         //Echo pin
long Duration = 0;
  pinMode(TriggerPin, OUTPUT); // Trigger is an output pin
  pinMode(EchoPin, INPUT);     // Echo is an input pin
  Serial.begin(9600);          // Serial Output
  digitalWrite(TriggerPin, LOW);
  delayMicroseconds(2);
  digitalWrite(TriggerPin, HIGH);          // Trigger pin to HIGH
  delayMicroseconds(10);                   // 10us high
  digitalWrite(TriggerPin, LOW);           // Trigger pin to HIGH
  Duration = pulseIn(EchoPin, HIGH);       // Waits for the echo pin to get high
  // returns the Duration in microseconds
  long Distance_cm = Distance(Duration);   // Use function to calculate the distance
  Serial.print("Distance = ");             // Output to serial
  Serial.print(Distance_cm);
  Serial.println(" cm");
  delay(1000);                             // Wait to do next measurement
long Distance(long time)
  long DistanceCalc;                      // Calculation variable
  DistanceCalc = ((time * 0.034) / 2);     // Actual calculation in cm
  //DistanceCalc = time / 74 / 2;         // Actual calculation in inches
  return DistanceCalc;                    // return calculated value
Sketch uses 3144 bytes (10%) of program storage space. Maximum is 30720 bytes.
Global variables use 204 bytes (9%) of dynamic memory, leaving 1844 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
An error occurred while uploading the sketch
spycatcher2k
Try choosing processor 328 old bootloader from the Boards menu.Retry and tell us what happens.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
