Topic: Displaying temperature and pressure at the same time using java  (Read 594 times) previous topic - next topic
neiklot
note to self: must check what an Arduino actually does with a runtime error like that.
brunopeniche
This:
Serial.println(sensor2);
Needs to change now to:
 Serial.print(sensor2);
wow thanks!!! It worked!! So what is the difference of putting Serial.println instead of Serial.print? the "ln" kind of finishes the line where the data is displayed, with the next values being displayed in the next paragraph?
brunopeniche
long a =1023 - analogRead(analogPin);
If analogRead returns 1013.
So if the analog read of the thermistor gives 1013 the code will have some kind of error, right? Do you guys then think that I should change the code? Because that equation was really the best that I found to display the temperature in degrees celsius
neiklot
Yes, and more "technically" it inserts a CR carriage return (to go back to the left) and a LF line feed (to click one line ahead) into the stream sent to the monitor.
Have a Google for the ascii table, and you will see character hex 0D, or decimal 13 is the CR and 0A or 10 is the LF.
brunopeniche
Thanks!!
PaulS
Can you explain, please? ahah
I was seeing parentheses where I would have put them, not where you didn't put them.
You are dividing by a. If a is ever 0, you are doing A BAD THING.
You SHOULD be using parentheses to make it clear how that equation is to be evaluated.
brunopeniche
Ok, I have put the equation like this now:
float sensor1 = beta /(log(((1025.0 * 10 / a) - 10) / 10) + beta / 298.0) - 273.0;
instead of:
float sensor1 = beta /(log((1025.0 * 10 / a - 10) / 10) + beta / 298.0) - 273.0;
And it seems fine. Do you agree with that?
PaulS
No. You are still dividing by a, even if a is 0.
brunopeniche
Oh yeah. So how you suggest me to change it? I would have to change to another equation?
PaulS
if(a != 0)
   sensor1 = someOtherValue;
I have no idea what you want to use as someOtherValue, when a is 0.
brunopeniche
if(a != 0)
I dont know, maybe the result of the equation when a=0.00001? Is it correct?
PaulS
Since you have declared a to be an integral type, setting it to 0.000001 seems unlikely.
brunopeniche
sorry for not answering sooner but I was out of this project for 2 days. So what value do you recommend? I sincerely dont know ahah
