Topic: Arduino Nano Transmitter as replacement for iA6 receiver  (Read 169 times) previous topic - next topic
Addy
I have searched the web and found very little, so I guess it cannot be done!  But just in case!
I have a working iA6 RC receiver, but a broken transmitter.
Can I use a Arduino Nano with a 2.4Ghz transceiver module?  If I can, how do I find the serial/code/id which will allow the Nano Transmitter to communicate?
Looking to save having to buy a new one, and learn something whist saving.
Many Thanks
Addy
Paul_KD7HB
Many Thanks
Addy
IF you searched the web already, then give us a little help, too. What did you find for a data sheet on your iA6 RC receiver? You have the receiver and stuff, but we don't.
What 2.4 gHz transceivers did you find that can talk to the receiver? Any data sheets on them?
Paul
Addy
Hi Paul,
I found very little with regards to the transmitter, but you can read signals by hooking up the receiver to an Arduino.
This lead me to believe that it is straight forward to code using an iA6 receiver based on what it receives, but nothing from the Transmitter side.  I would, I guess, need some tool which can read 2.4Ghz signals and look for changes whilst moving the controls on the transmitter to isolate the signal to that one controller.
So when I see a change from the signal tool, and the serial hooked up to the receiver (via Arduino) I would see the changes.  However, even if I had these, I would not have the id / code which would allow my Arduino Transmitter too talk to my receiver (iA6).  So I would need to know what ID is sent with each signal to allow my receiver to read it.   Also, thinking about it I would also need a working iA6 transmitter, and a tool to read signals.
Perhaps I should just not be cheap and buy a new controller?
