Topic: Kitschpatrol-Brain-Grapher not uploading to Arduino (Read 276 times) previous topic - next topic
dj_sirju1997
Hey everyone, I'm trying to get readings from my Force Trainer II headset using the brain grapher and Arduino brain library.
The BrainSerialTest file is uploading just fine, but I'm not getting a serial output, and the connection to the headset is good (T-pin connected as well as ground).
When I try to run the BrainGrapher.pde I keep getting the error shown below. If anyone could offer some explanation or a solution it would be greatly appreciated.
ERROR MESSAGES
Arduino: 1.8.9 (Mac OS X), Board: "Arduino/Genuino Uno"
BrainGrapher:9:1: error: 'import' does not name a type
 import processing.serial.*;
BrainGrapher:10:1: error: 'import' does not name a type
 import controlP5.*;
BrainGrapher:12:1: error: 'ControlP5' does not name a type
 ControlP5 controlP5;
BrainGrapher:14:1: error: 'Serial' does not name a type
 Serial serial;
BrainGrapher:16:1: error: 'Channel' does not name a type
 Channel[] channels = new Channel[11];
BrainGrapher:17:1: error: 'Monitor' does not name a type
 Monitor[] monitors = new Monitor[10];
BrainGrapher:18:1: error: 'Graph' does not name a type
 Graph graph;
BrainGrapher:19:1: error: 'ConnectionLight' does not name a type
 ConnectionLight connectionLight;
BrainGrapher:118:18: error: variable or field 'serialEvent' declared void
 void serialEvent(Serial p) {
BrainGrapher:118:25: error: expected ')' before 'p'
/Users/dorian/Downloads/kitschpatrol-BrainGrapher-31cc148/BrainGrapher/BrainGrapher.pde: In function 'void setup()':
BrainGrapher:27:17: error: 'size' was not declared in this scope
   size(1024, 768);
BrainGrapher:28:15: error: 'frameRate' was not declared in this scope
   frameRate(60);
BrainGrapher:29:10: error: 'smooth' was not declared in this scope
   smooth();
BrainGrapher:30:3: error: 'surface' was not declared in this scope
   surface.setTitle("Processing Brain Grapher");
BrainGrapher:33:69: error: 'println' was not declared in this scope
   println("Find your Arduino in the list below, note its [index]:\n");
BrainGrapher:35:30: error: 'class HardwareSerial' has no member named 'list'
   for (int i = 0; i < Serial.list().length; i++) {
BrainGrapher:36:23: error: invalid operands of types 'const char*' and 'const char [3]' to binary 'operator+'
     println("[" + i + "] " + Serial.list());
BrainGrapher:36:37: error: 'class HardwareSerial' has no member named 'list'
BrainGrapher:40:3: error: 'serial' was not declared in this scope
   serial = new Serial(this, Serial.list()[0], 9600);
BrainGrapher:40:16: error: expected type-specifier before 'Serial'
BrainGrapher:45:3: error: 'controlP5' was not declared in this scope
   controlP5 = new ControlP5(this);
BrainGrapher:45:19: error: expected type-specifier before 'ControlP5'
BrainGrapher:47:39: error: 'color' was not declared in this scope
   controlP5.setColorValueLabel(color(0));
BrainGrapher:55:3: error: 'channels' was not declared in this scope
   channels[0] = new Channel("Signal Quality", color(0), "");
BrainGrapher:55:21: error: expected type-specifier before 'Channel'
BrainGrapher:56:21: error: expected type-specifier before 'Channel'
   channels[1] = new Channel("Attention", color(100), "");
BrainGrapher:57:21: error: expected type-specifier before 'Channel'
   channels[2] = new Channel("Meditation", color(50), "");
BrainGrapher:58:21: error: expected type-specifier before 'Channel'
   channels[3] = new Channel("Delta", color(219, 211, 42), "Dreamless Sleep");
BrainGrapher:59:21: error: expected type-specifier before 'Channel'
   channels[4] = new Channel("Theta", color(245, 80, 71), "Drowsy");
BrainGrapher:60:21: error: expected type-specifier before 'Channel'
   channels[5] = new Channel("Low Alpha", color(237, 0, 119), "Relaxed");
BrainGrapher:61:21: error: expected type-specifier before 'Channel'
   channels[6] = new Channel("High Alpha", color(212, 0, 149), "Relaxed");
BrainGrapher:62:21: error: expected type-specifier before 'Channel'
   channels[7] = new Channel("Low Beta", color(158, 18, 188), "Alert");
BrainGrapher:63:21: error: expected type-specifier before 'Channel'
   channels[8] = new Channel("High Beta", color(116, 23, 190), "Alert");
BrainGrapher:64:21: error: expected type-specifier before 'Channel'
   channels[9] = new Channel("Low Gamma", color(39, 25, 159), "Multi-sensory processing");
BrainGrapher:65:22: error: expected type-specifier before 'Channel'
   channels[10] = new Channel("High Gamma", color(23, 26, 153), "???");
BrainGrapher:79:23: error: 'monitors' was not declared in this scope
   for (int i = 0; i < monitors.length; i++) {
BrainGrapher:80:23: error: expected type-specifier before 'Monitor'
     monitors = new Monitor(channels[i + 1], i * (width / 10), height / 2, width / 10, height / 2);
BrainGrapher:83:3: error: 'monitors' was not declared in this scope
   monitors[monitors.length - 1].w += width % monitors.length;
BrainGrapher:83:38: error: 'width' was not declared in this scope
BrainGrapher:86:3: error: 'graph' was not declared in this scope
   graph = new Graph(0, 0, width, height / 2);
BrainGrapher:86:15: error: expected type-specifier before 'Graph'
BrainGrapher:89:3: error: 'connectionLight' was not declared in this scope
   connectionLight = new ConnectionLight(width - 140, 10, 20);
BrainGrapher:89:25: error: expected type-specifier before 'ConnectionLight'
/Users/dorian/Downloads/kitschpatrol-BrainGrapher-31cc148/BrainGrapher/BrainGrapher.pde: In function 'void draw()':
BrainGrapher:94:33: error: 'channels' was not declared in this scope
   if (scaleMode == "Global" && (channels.length > 3)) {
BrainGrapher:101:17: error: 'background' was not declared in this scope
   background(255);
BrainGrapher:104:3: error: 'graph' was not declared in this scope
   graph.update();
BrainGrapher:108:3: error: 'connectionLight' was not declared in this scope
   connectionLight.update();
BrainGrapher:112:23: error: 'monitors' was not declared in this scope
/Users/dorian/Downloads/kitschpatrol-BrainGrapher-31cc148/BrainGrapher/BrainGrapher.pde: At global scope:
exit status 1
option enabled in File -> Preferences.
pert
BrainGrapher.pde is a Processing program. You run it on your computer using the Processing IDE. You can't run that code on your Arduino board.
https://processing.org
