Topic: 'byte index' redeclared as different kind of symbol error (Read 70 times) previous topic - next topic
nguyenpt
Hi guys.
Yesterday, I complied this program and it run well. Now, I'm rebuilting it and some errors occurt.
Can you tell me how to fix that?
I cannot understand why same code but not same result.
Many thanks.
char inData[24];
byte index;
boolean started = false;
boolean ended = false;
Serial.println("Temperature & Humidity");
  while(Serial.available() > 0)
char aChar = Serial.read();
if(aChar == '<')
    started = true;
    index = 0;
    inData[index] = '\0';
else if(aChar == '>')
    ended = true;
else if(started)
    inData[index] = aChar;
    index++;
    inData[index] = ',';
  if(started && ended)
// Use the value
if(inData[0] == 'T')
   inData[0] = ' ';
   int windVal = atoi(inData);
           Serial.println(" ");
   Serial.print("Temp:");
           Serial.print(inData);
           Serial.print("C");
else if(inData[0] == 'H')
   inData[0] = ' ';
           int temp = atoi(inData);
           Serial.print("Humidity:");
           Serial.print("%");
started = false;
ended = false;
index = 0;
AWOL
I compiled your code, and got the following error message
Sketch uses 1726 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 257 bytes (12%) of dynamic memory, leaving 1791 bytes for local variables. Maximum is 2048 bytes.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
