Topic: pairing rejected by HC05 (Read 165 times) previous topic - next topic
vin_swadi
I am unable to BT pair for anroid  mobile with HC05, after clicking pair on mobile screen receiving error message "pairing rejected by HC05". please help
Power_Broker
Did you put in the passcode for the HC-05 in your android app? Can you post your code and description of your project?
"The desire that guides me in all I do is the desire to harness the forces of nature to the service of mankind."
   - Nikola Tesla
vin_swadi
NO password,
here is code
 *  Bluetooh Basic: LED ON OFF - Avishkar
 *  Coder - Mayoogh Girish
 *  Website - http://bit.do/Avishkar
 *  Download the App :
 *  This program lets you to control a LED on pin 13 of arduino using a bluetooth module
char Incoming_value = 0;                //Variable for storing Incoming_value
  Serial.begin(9600);         //Sets the data rate in bits per second (baud) for serial data transmission
  pinMode(13, OUTPUT);        //Sets digital pin 13 as output pin
  if(Serial.available() > 0)
    Incoming_value = Serial.read();      //Read the incoming data and store it into variable Incoming_value
    Serial.print(Incoming_value);        //Print Value of Incoming_value in Serial monitor
    Serial.print("\n");        //New line
    if(Incoming_value == '1')            //Checks whether value of Incoming_value is equal to 1
      digitalWrite(13, HIGH);  //If value is 1 then LED turns ON
    else if(Incoming_value == '0')       //Checks whether value of Incoming_value is equal to 0
      digitalWrite(13, LOW);   //If value is 0 then LED turns OFF
Power_Broker
NO password,
There's your problem (or, at least one of them) right there. HC-05's have a default password/pin of '1234' and this password/pin is required by the phone when pairing and connecting to the HC-05
   - Nikola Tesla
