Topic: Bluetooth controlled car with Ultrasonic sensor and MIT app inventor (Read 134 times) previous topic - next topic
HizonPastor
Hi everyone,
I am recently making a project, a bluetooth controlled car that can receive and send data or ascii files with one bluetooth module and one arduino (with L293D motor shield)
I'm trying to use MIT app inventor as the remote control
I get a problem when I try to compile my code, and the error is: expected `}' at end of input.
I've checked the parts that I recently added/changed, tried to fix them, but nothing.
Here is my code:
#include <AFMotor.h>
#include <Servo.h>
const int trigPin = 3; const int echoPin = 2; long duration, cm;
AF_DCMotor left1Motor(1, MOTOR12_1KHZ);
AF_DCMotor left2Motor(2, MOTOR12_1KHZ);
AF_DCMotor right1Motor(3, MOTOR34_1KHZ);
AF_DCMotor right2Motor(4, MOTOR34_1KHZ);
Servo servo1;
Servo servo2;
#define right1Speed 200
#define right2Speed 200
#define left1Speed 200
#define left2Speed 200
String readString;
  servo1.attach(10);
  servo2.attach(9);
  servo1.write(0);
  servo2.write(0);
Serial.begin(9600);  pinMode(trigPin, OUTPUT);  pinMode(echoPin, INPUT);
  right1Motor.setSpeed(right1Speed);
  right2Motor.setSpeed(right2Speed);
  left1Motor.setSpeed(left1Speed);
  left2Motor.setSpeed(left2Speed);
  while (Serial.available()) {
    delay(50);
    char c = Serial.read();
    readString += c;
  if (readString.length() > 0) {
    Serial.println(readString);
    if (readString == "FORWARD") {
      right1Motor.run (FORWARD);
      right2Motor.run (FORWARD);
      left1Motor.run (FORWARD);
      left2Motor.run (FORWARD);
    if (readString == "BACK") {
      right1Motor.run (BACKWARD);
      right2Motor.run (BACKWARD);
      left1Motor.run (BACKWARD);
      left2Motor.run (BACKWARD);
    if (readString == "COUNTER") {  //Left
    if (readString == "CLOCKWISE") {  //Right
    if (readString == "STOP") {
      right1Motor.run (RELEASE);
      right2Motor.run (RELEASE);
      left1Motor.run (RELEASE);
      left2Motor.run (RELEASE);
    if (readString == "TAPON") {
      servo1.write(90);
    servo1.write(0);
    if (readString == "KUHAIN") {
      servo2.write(90);
    servo2.write(0);
    readString = "";
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  cm = (duration/2)/29.1;
  if(cm < 20)
    Serial.print("d"); delay(400);
    Serial.print("n"); delay(400);
slipstick
And what do you get when you put the extra } at the end as it suggests?
Steve
