Topic: Yun crashes when capturing a frame from webcam (Read 203 times) previous topic - next topic
duino7771
Hi all,
I have a HD USB webcam (UCV) plugged into my yun through a powered USB hub (2Am).
Yun itself is powered from 1.8Am phone charger.
Camera specs: http://www.elpcctv.com/5mp-hd-wide-anagle-fisheye-lens-usb-camera-with-yuy-and-mjpef-output-p-84.html
When I attach camera it is recognised:
Code: [Select]
Apr  3 15:06:11 kern.info kernel: [  581.190000] usb 1-1.1.4.4: USB disconnect, device number 6
Apr  3 15:06:15 kern.info kernel: [  585.270000] usb 1-1.1.4.4: new high-speed USB device number 7 using ehci-platform
Apr  3 15:06:15 kern.info kernel: [  585.380000] usb 1-1.1.4.4: New USB device found, idVendor=05a3, idProduct=9520
Apr  3 15:06:15 kern.info kernel: [  585.380000] usb 1-1.1.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Apr  3 15:06:15 kern.info kernel: [  585.390000] usb 1-1.1.4.4: Product: HD USB Camera
Apr  3 15:06:15 kern.info kernel: [  585.390000] usb 1-1.1.4.4: Manufacturer: HD Camera Manufacturer
Apr  3 15:06:15 kern.info kernel: [  585.400000] uvcvideo: Found UVC 1.00 device HD USB Camera (05a3:9520)
Apr  3 15:06:15 kern.info kernel: [  585.530000] input: HD USB Camera as /devices/platform/ehci-platform/usb1/1-1/1-1.1/1-1.1.4/1-1.1.4.4/1-1.1.4.4:1.0/input/input2
When I try to use fswebcam with following settings:
Code: [Select]
device /dev/video0
input 0
frames 1
skip 0
fps 1
dumpframe /mnt/sda1/frame
resolution 160x120
jpeg 50
save /mnt/sda1/viewcam.jpg
palette MJPEG
I get the following:
Code: [Select]
/mnt/sda1# fswebcam -c  fswebcam.conf
--- Opening /dev/video0...
Trying source module v4l2...
/dev/video0 opened.
Adjusting resolution from 160x120 to 320x240.
--- Capturing frame...
packet_write_wait: Connection to 192.168.178.59 port 22: Broken pipe
After that Yun is just rebooting without any output in syslog.
Is it something with the camera? It works with my notebook.
Could someone advise me how to make it work?
Thanks
