Topic: 1.6" LCD SSD1283A colour display - which library? (Read 454 times) previous topic - next topic
kaspencer
Apr 08, 2019, 03:56 pm Last Edit: Apr 08, 2019, 03:57 pm by kaspencer
Good afternoon, all.
I am trying to drive a 1.6" x 1.6" 65K colour LCD module, which uses the SSD1283A driver electronics. I will be using the SPI interface. I have used, and am familiar, with several other OLED types, but I have not been able to locate a library for this device.
Might I ask whether anyone might be able to point me in the right direction for locating a compatible graphics driver/library, preferably for the Arduino Due?
Thanks
Kenneth Spencer
david_prentice
I can't find a datasheet.
I suspect it is a 132x162 controller like ST7735, ILI9163, ...
I can find this pcb from AliExpress.
Have you received your screen yet?
Can you read the part numbers of the LDO, transistor, i.c. ??? on the pcb?
David.
kaspencer
Thanks, David ...
... I have received two of them.
The "driver chip" is stated to be the SSD1283A. The two I have are exactly as per your link. The resolution is 130x130 (actually 132 x 132 as per the datasheet) as the panel is square, at 1.6" diagonal.
I have attached a datasheet, but it didnt help me to identify a driver/library - maybe it will help you!
I have already used 2.8" (240x320) TFT devices in another project, which take the ILI9341 library. In hope, I tried that library with the SSD1283, and that doesn't work.
I can just about read the details on the 20 pin SMC on the back of the PCD, it looks like:
 LVCV24SA (possibly 5A)
 SE4641
 TXD750F
There is a chip on the front of the PCB as well, but it is covered by what might be a heat sink, except that it has a flexi-print strip which passes under the display module twoards the centre of the device.
I cannot find a reference anywhere to a driver or library for this device, but I was hoping that one of the ILIxxxx libraries would work. Following your mention of the ST7735 and the ILI9163 libraries, I will give those a go.
Thanks - stilll in hope ...
Kenneth Spencer
david_prentice
If your module looks like the link that I posted in #1,  it has a 4-wire SPI interface.   i.e. 8-bit SPI + DC.
I suspected that SSD1283 might  be similar to SSD1289 i.e.  unlike the rest of the civilised world.
If you have a LVC245 it means you can safely use 5V GPIO e.g. Uno, Mega, ...
It will take a bit of effort to write a driver without the display on my desk.   Is it high quality sunlight readable?
Are you in Europe?   Do you have a GitHub account?
David.
Imagine that an explorer found a job lot of Fred Flintstone's motor cars.
You could sell them on Ebay / Ali.
The "performance" would not be as good as modern cars.
Someone in China has found a warehouse full of obsolete TFT screens.
kaspencer
#4
Apr 13, 2019, 01:16 am Last Edit: Apr 13, 2019, 01:22 pm by kaspencer
Thanks David ...
... I am in the UK - England, South West.
I am using an Arduino Due with this project because I need 60 (CS = 1-60) Monochrome OLEDs all using SPI (CS lines used to address them all) and one TFT colour display. The code is all written for the mono devices, the colour TFT is CS = 61 and the last bit of code to write. (The device actually has 4 Dues, a Mega, a Nano and a Teensy in it!).
The Due is 3.3V (as you no doubt know) and drives an ILI9341 with no issues. All the Mono OLEDs are SSD1306 and are happy with 3.3V too. Unfortunately the ILI9341 is just a bit too big for this project, hence the SSD1283A which is a perfect size.
I do have a github a/c, yes. If there is any chance that you'd write a driver/library, and if you are in the UK, I might consider sending you one of the TFTs to work with.
I haven't had a chance to try the ILI9163 or the ST7735 yet, but I will.
Thanks again,
Kenneth Spencer
david_prentice
Yes,  I am in the UK.
The ST7735 or ILI9163 would be much easier.   They are both MIPI controllers.    And I think that both are still in production.
240x240 ST7789 displays are 1.5 inch
The SSD1283 is well obsolete.    It all depends on how big a stash of obsolete screens have been dumped on the surplus market.
David.
kaspencer
Thanks David ...
... I think I have found a library. I don't want to attach it to this thread, but if you email me (kenneth ...at... kaspencer ...dot... com) I will send it to you and you can look at it and tell me what you think. I am going to test it but it won't be for a few days now.
I'm sure that you'll be able to offer a better judgement on its possible use than I can! But it does appear to have all the necessary functions.
Best wishes,
Kenneth Spencer
cndg
I modded this one to work on arduino (atmega328p in a pro-mini 3.3v):
https://github.com/gitcnd/LCDWIKI_SPI
with this init code:
Code: [Select]
LCDWIKI_SPI mylcd(MODEL,CS,CD, MISO, MOSI, RST, SCK, LED);
If you need it to be 10 times faster and wire data+clock to pins 11 and 13 you can paste this snippet in there:
https://www.avrfreaks.net/comment/2696096#comment-2696096
david_prentice
Please try my Fork(s):
https://github.com/prenticedavid/LCDWIKI_SPI
https://github.com/prenticedavid/LCDWIKI_gui
I never got any feedback from kaspencer.  If you own a SSD1283 display it would be nice to know if it works.
LCDWIKI has extremely unusual method syntax.   It works (on ILI9341 and ST7735) but is rather slow.
David.
danewatkins
Hi David
Thanks for the fork and comments. I bought ten of these screens before I realised how useless they are.
I just tried your fork but I can't see how it is different to the original code. I have it working off a nodemcu but the loop stops, which might be what you are saying in the readme "ESP8266 will timeout without lots of yield() calls." Is the esp reset from one of the other library functions? Not quite sure how to do the yield calls.
Do you know how I might use xbm images? Or should I just throw the screens away?
Dane
david_prentice
#10
May 30, 2019, 07:55 pm Last Edit: May 30, 2019, 07:56 pm by david_prentice
The edits in my Fork are in the "tidy up" and "port to other platform" rather than "radical change".
The first question is:   Does the display have good colours and angle of view?
i.e.  is it worth the effort?
I was not expecting an ESP8266 user.   I will put in the yield()s into example(s).
The library design is pretty inefficient.
Any particular XBM image?
Stationary images or animation?
David.
david_prentice
I have not heard from you.
I have added an XBM example to my Fork.   And a more convenient way to configure Hardware SPI.
David.
Cleiton_Iida
#12
Jun 10, 2019, 07:06 pm Last Edit: Jun 10, 2019, 07:20 pm by Cleiton_Iida
An Aliexpress buyer reported that successfully drove the SSD1283A using the following driver from LCD wiki:
http://www.lcdwiki.com/1.6inch_SPI_Module_ESP8266_SSD1283A_SKU:MSP1601
There you can find the 1.6in Color TFT datasheet  in the following link:
http://www.lcdwiki.com/res/MSP1601/H016IT01_V0_Ver.0_20041106_201407195970.pdf
You can also find the SSD1283 datasheet in the following link:
http://www.lcdwiki.com/res/MSP1601/SSD1283A%20Datasheet.pdf
Cleiton Iida.
david_prentice
Yes,  you can use it with ESP8266.   It is incredibly SLOW.    So you must inset lots of yield() statements to avoid the WatchDog biting you.
If a reader owns a SSD1283 display,  please could you leave a message here.
No one responds to LCDWIKI GitHub page.
David.
