Topic: avrdude: ser_open(): can't open device "/dev/ttyACM0": Permission denied (Read 302 times) previous topic - next topic
RiccardoF88
Hello all,
I'm not new to the Forum, but as long as I can remember... I've never wrote in it...
I'm having an issue with the Arduino IDE on Ubuntu 18.10:
When I try to upload a sketch on the Arduino UNO I receive this error message
Code: [Select]
An error occurred while uploading the sketch
The solutions I've already tried (most common solutions found in internet so far):
-Check that the board is seen by Ubuntu from terminal
ricky@Elitebook-8440p:~$ ls /dev/ttyACM0
/dev/ttyACM0
ricky@Elitebook-8440p:~$ ls /dev/ttyACM1
/dev/ttyACM1
ricky@Elitebook-8440p:~$ ls -l /dev/ttyACM0
crw-rw-rw- 1 root dialout 166, 0 apr 13 10:22 /dev/ttyACM0
ricky@Elitebook-8440p:~$ ls -l /dev/ttyACM1
crw-rw-rw-+ 1 root dialout 166, 1 apr 13 10:22 /dev/ttyACM1
-Check/Grant the permissions of my user
ricky@Elitebook-8440p:~$ sudo usermod -a -G tty ricky
ricky@Elitebook-8440p:~$ sudo usermod -a -G dialout ricky
ricky@Elitebook-8440p:~$ sudo chmod a+rw /dev/ttyACM0
ricky@Elitebook-8440p:~$ sudo chmod a+rw /dev/ttyACM1
So far I keep receiving the same message.
does anyone had this issue?
is this a common bug of the IDE on Ubuntu?
Ps: in windows it all works fine, no issues (but I don't have a windows pc anymore)
Robin2
Have you added yourself to the dialout group?
That is the only thing I ever needed to do.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
pert
After doing that, did you log out and then log back in to your Linux user account?
ron_sutherland
#3
Apr 17, 2019, 02:50 am Last Edit: Apr 17, 2019, 02:55 am by ron_sutherland Reason: color not work in code block
Might also unplug and plug the usb and have a look at dmesg.
Welcome to Ubuntu 18.04.2 LTS (GNU/Linux 4.15.0-47-generic i686)
rsutherland@conversion:~$ dmesg
[22212.826279] usb 3-2: USB disconnect, device number 2
[22220.266246] usb 3-2: new full-speed USB device number 3 using uhci_hcd
[22220.494252] usb 3-2: New USB device found, idVendor=2341, idProduct=0043
[22220.494257] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[22220.494261] usb 3-2: Manufacturer: Arduino (www.arduino.cc)
[22220.494264] usb 3-2: SerialNumber: 95233353131351E0E0F0
[22220.497395] cdc_acm 3-2:1.0: ttyACM0: USB ACM device
well that was fun to color
I use an R-Pi Zero on an RPUpi shield to have a tool-chain at the network edge.
