Topic: Numerous Arduino upload errors (Read 61 times) previous topic - next topic
TDC302
I'm trying to output the distance from the ultrasonic sensor on the Arduino LCD screen.
Here is my code:
Code: [Select]
#include <LiquidCrystal.h>
// defines pins numbers
const int trigPin = 7;
const int echoPin = 8;
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// defines variables
long duration;
int distance;
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
//Starts the lcd screen.
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("TEST :D");
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
// Prints the distance on the lcd display.
lcd.print("Distance:");
lcd.print(distance);
Now I did copy a lot of it out of tutorials and I don't have an Arduino, I have an Elegoo Uno R3 (off brand Arduino (uses the same programming software)) but when I try to upload the code (it verifies fine) it takes a very long time and then gives me this:
Code: [Select]
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 2974 bytes (9%) of program storage space. Maximum is 32256 bytes.
Global variables use 65 bytes (3%) of dynamic memory, leaving 1983 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\tdc30\AppData\Local\Temp\arduino_build_117184/sketch_apr14a.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM1
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x79
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x79
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x79
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x79
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x79
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x79
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x79
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x79
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x79
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x79
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I have no idea what that means.
Also, I'm kinda new to Arduino and while I have done other programs I'm not a pro at this.
pert
Remove any connections to pins 0 and 1. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don't know which port is your Arduino, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
