Topic: Arduino won't compile (Read 70 times) previous topic - next topic
specht555
I keep getting this error:
opening dependency file /dev/null.d: Operation not permitted compilation terminated.
When I searched for null.d in my terminal nothing would come up. I could find null, but null.d wasn't there.
Is this because I am trying use the mac os x arm-linux-guneabihf on the new mac mojave os?
pert
Please do this:
  • (In the Arduino IDE) click File > Preferences
  • Check the box next to "Show verbose output during: > compilation
  • Click "OK"
  • Sketch > Verify/Compile
  • After the compilation fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the compilation output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
If the length of the output exceeds the forum's 9000 character limit, save it in a .txt file and post it here as an attachment. If you click the "Reply" button you'll see the "Attachments and other options" link.
It's possible the verbose output will give us a clue to what the problem is.
