Topic: Connecting 2 ADXL345 Accelerometer sensors over I2C (Read 276 times) previous topic - next topic
Harinder85
Hi !
I am working on a project and need to connect 2 accelerometers. ADXL345 is the sensor I am working using. I2C Address and alternate address for the same is 0x1D and 0x53.
If i don't give an address while initializing the object, it works, but both sensors give same output
If i give address as 0x1D the sensor gives output as 0
If i Give address as 0x53 there is no output.
I want to read the data from both the sensors.
ADXL345 Accelerometer:
https://robu.in/product/adxl345-tripple-axis-accelerometer-board/?gclid=Cj0KCQiA-8PjBRCWARIsADc18TLzIZjSFGcHNeAvvxHKwt22WEjE3Y-f-jte0CEpljUGM-f55tGH_lMaAhd4EALw_wcB
jremington
#1
Apr 16, 2019, 05:23 am Last Edit: Apr 16, 2019, 05:24 am by jremington
To change the I2C address of one of the modules to 0x53, ground the ALT_ADDRESS pin. Details are in the ADXL345 data sheet.
Harinder85
#2
Apr 16, 2019, 12:37 pm Last Edit: Apr 16, 2019, 12:40 pm by Harinder85
I have already connected SDO pin of one sensor to ground and the other sensors SDO pin is connected to 5V.
used I2C scanner sketch and it outputs the addresses as 0x1D and 0x53 for the connected devices.
But it does't work
jremington
According to the github source, the library you are using has a single, hard wired I2C address:
Code: [Select]
#define ADXL345_DEVICE (0x53) // Device Address for ADXL345
This would never work for two devices.
Harinder85
Ok, I got it !
Is there some other library so I can connect 2 ADXL345 Accelerometers?
jremington
Harinder85
#6
Apr 19, 2019, 05:24 pm Last Edit: Apr 19, 2019, 05:25 pm by Harinder85
got it done using wire.h only
Thanks for the help !
jremington
Great! Please post your code, to help others with the same problem.
Harinder85
Following is the code for same
Code: [Select]
#include<Wire.h>
#define accel_module (0x1d)         // SDO-> Vcc
#define accel_module2 (0x53)       // SDO-> GND
byte values[6];
byte values2[6];
char output[512];
char output2[512];
void getAccelration(int accelSensor, int cal)
  int xyzregister = 0x32;
  int x, y, z;
  Wire.beginTransmission(accelSensor);
  Wire.write(0x2D);
  Wire.write(0);
  Wire.endTransmission();
  Wire.write(0x2D);
  Wire.write(16);
  Wire.write(0x2D);
  Wire.write(8);
  Wire.write(xyzregister);
  Wire.requestFrom(accelSensor, 6);
  int i = 0;
  while(Wire.available())
    values[i] = Wire.read();
    i++;
  x = (((int)values[1]) << 8) | values[0];
  y = (((int)values[3])<< 8) | values[2];
  z = (((int)values[5]) << 8) | values[4];
  sprintf(output, "%d",z-cal);
  Serial.print(output);
  Wire.begin();
  getAccelration(accel_module, 205); // ********accel 0x1D*********//
  Serial.print("    From2: ");
  getAccelration(accel_module2, 28);  //*******accel 0x53********//
  delay(200);
