Topic: Serial on St Nucleo L432KC (Read 169 times) previous topic - next topic
Sil83
Dear all,
I am trying to use the serial on ST NUCLEO-L432KC.
I tryed different things but apparently without any result.
Could someone of you help me, please?
Silvano
Eng. Silvano Bertoldo, PhD
DrAzzy
You might want to try the forum for the hardware package (aka "core") you're using - the STM32 and ESP people have their own forums on different websites. I know stm32duino has a forum.
While we see questions about STM32 semi-regularly (particularly recently), there seem to be few if any people who are experienced with STM32 here to answer them.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
Sil83
Ok, thank you for the answer.
The only problem is that stm32duino is closed...
I just asked here because Nucleo32 L432KC is a compatible Arduino Board.
Silvano
BJHenry
I checked there today and Roger is actually pushing back the read-only close date into May, so you can still ask questions there.
Sil83
#4
Apr 19, 2019, 08:11 am Last Edit: Apr 19, 2019, 08:12 am by Sil83
I already know that!
The problem is that such forum is read only and I cannot questions anymore unless you were registered in the past (and I was not, because I have been working on STM32 board since 2 weeks ago)...
I would appreciate if someone could kindly help me here. But maybe it is not the proper place, as far as I understood, since it seems that everybody registere here should already know everything about Arduino and compatible boards.
Anyway, no problem, thanks again!
westfw
Quote
it seems that everybody registered here should already know everything about Arduino and compatible boards.
Nope.  In particular, "compatible boards" that have historically had their own adequate forums (PICKit, Adafruit, Sparkfun, STM32Duino, etc.)
I haven't been following STM32 Arduino Core(s) at all recently; is there some summary somewhere of what's going on?  There seem to be several "cores" supporting different board sets, all of which have been using the stm32duino.com forums for discussion?  (No wonder Roger wants to move on!)
In any case:
  • calling the L432kc "Arduino compatible" seems to be "stretching."  I don't see it mentioned in the stm32duino wiki, or mentioned much in the forums.  It seems to be in the https://github.com/stm32duino/Arduino_Core_STM32, but.  ST mentions that the board has an Arduino Nano pinout, but doesn't claim Arduino IDE compatibility...
  • Your initial post doesn't really contain enough data for even an STM32 expert to offer any solution.  What core are you using?  What is the "problem"?  What have you tried?  See How to use this forum
  • Did you see https://github.com/stm32duino/Arduino_Core_STM32/issues/362 ?  Are you running a core newer than that fix?
DrAzzy
It sounds like STM has taken over stm32duino development. Meaning its about to either get way better, or way worse.
westfw
Quote
Could be both!  With a vendor, I'd worry about over-supporting new products while neglecting the older boards.  A lot of the interest in STM32duino is based on the really cheap STM32F103 boards, and I suspect that ST would rather people used their newer boards...
