Topic: Parsing numbers from a serial input (Read 119 times) previous topic - next topic
phenyl
Apr 17, 2019, 09:56 pm Last Edit: Apr 17, 2019, 10:05 pm by phenyl
I am trying to parse some ADC values that I am getting from a device via Serial1 (here simulated by an array in the header). As we have devices with different numbers of ADC, I would like to generalize my solution a bit, but I am banging my head against the different functions (strtoll seems useful...)
So at the moment I "hardcoded" the concatenation, but I am sure that there has to be a neat version based on starting position and number of bytes
uint8_t counter = 4 * nSensor;
    for (byte i = 3; i < (4 + counter); i++)
in order to generallize this mess:
  valueshex[0] = ((uint32_t)receivedBytes[3] << 24) | ((uint32_t)receivedBytes[4] << 16) | ((uint32_t)receivedBytes[5] << 8) | ((uint32_t)receivedBytes[6]);
    valueshex[1] = ((uint32_t)receivedBytes[7] << 24) | ((uint32_t)receivedBytes[8] << 16) | ((uint32_t)receivedBytes[9] << 8) | ((uint32_t)receivedBytes[10]);
    valueshex[2] = ((uint32_t)receivedBytes[11] << 24) | ((uint32_t)receivedBytes[12] << 16) | ((uint32_t)receivedBytes[13] << 8) | ((uint32_t)receivedBytes[14]);
    valueshex[3] = ((uint32_t)receivedBytes[15] << 24) | ((uint32_t)receivedBytes[16] << 16) | ((uint32_t)receivedBytes[17] << 8) | ((uint32_t)receivedBytes[18]);
I would be grateful for any help to replace that with something neat XtoY and some for{..} loops.
Follows a code that simulates a test case which I verified working:
// Example 6 - Receiving binary data
// heavily modified from http://forum.arduino.cc/index.php?topic=396450
const byte numBytes = 32;
byte receivedBytes[numBytes] = {0x31, 0x30, 0x30, 0x00, 0x81, 0x2D, 0x15, 0x00, 0x76, 0x5C, 0xB8, 0x00, 0x70, 0xDB, 0xE3, 0x00, 0x70, 0x64, 0x35};
byte numReceived = 19;
//byte receivedBytes[numBytes];
//byte numReceived = 0;
uint8_t nSensor = 4;
byte messageRaw[] = {0x02, 0x30, 0x30, 0x30, 0x03};
uint32_t valueshex[] = {0, 0, 0, 0};
float voltage[] = {0.0, 0.0, 0.0, 0.0};
boolean newData = false;
  Serial.begin(57600);
  Serial1.begin(57600);
  while (!Serial) {}
  Serial.println("<Arduino is ready>");
  // Serial1.write(messageRaw, sizeof(messageRaw));
  fakeNewData();
  // recvBytesWithStartEndMarkers();
  showNewData();
  void recvBytesWithStartEndMarkers() {
  static boolean recvInProgress = false;
  static byte ndx = 0;
  byte startMarker = 0x02;
  byte endMarker = 0x03;
  byte rb;
  while (Serial1.available() > 0 && newData == false) {
    rb = Serial1.read();
    if (recvInProgress == true) {
      if (rb != endMarker) {
        receivedBytes[ndx] = rb;
        ndx++;
        if (ndx >= numBytes) {
          ndx = numBytes - 1;
      else {
        receivedBytes[ndx] = '\0'; // terminate the string
        numReceived = ndx;  // save the number for use when printing
        ndx = 0;
        newData = true;
    else if (rb == startMarker) {
      recvInProgress = true;
void fakeNewData() {
  newData = true;
  // receivedBytes =
void showNewData() {
  if (newData == true) {
    Serial.print("This just in (HEX values)... ");
    for (byte n = 0; n < numReceived; n++) {
      Serial.print(receivedBytes[n], HEX);
      Serial.print(' ');
    Serial.println();
      Serial.write(receivedBytes[n]);
      Serial.print(' ');
    Serial.println();
      Serial.print(receivedBytes[i], HEX);
    Serial.println();
    Serial.println(receivedBytes[3], HEX);
    Serial.println(receivedBytes[4], HEX);
    Serial.println(receivedBytes[5], HEX);
    Serial.println(receivedBytes[6], HEX);
    Serial.print("Val0 ");
    Serial.println(valueshex[0]);
    Serial.print("Val1 ");
    Serial.println(valueshex[1]);
    Serial.print("Val2 ");
    Serial.println(valueshex[2]);
    Serial.print("Val3 ");
    Serial.println(valueshex[3]);
    Serial.println();
    newData = false;
    for (uint8_t i = 0; i < 4; i++)
      voltage[i] = (((float)(valueshex[i]) / (16777216)) * 1856) - 928;
      Serial.println(voltage[i]);
The example should output:
<Arduino is ready>
This just in (HEX values)... 31 30 30 0 81 2D 15 0 76 5C B8 0 70 DB E3 0 70 64 35
 //one line of ASCII garbage//
0812D150765CB8070DBE307064350
81
2D
15
Val0 8465685
Val1 7756984
Val2 7396323
Val3 7365685
8.53
-69.87
-109.77
-113.16
phenyl
I have managed to put the hardcoded calculations in a loop, generalizing it, so I can change the number of sensors. However, I still think there would be an even easier way?
    for (byte i = 0; i < nSensor; i++)
      valueshex[i] = 0;
      for (uint8_t j = 0; j < 4; j++)
        valueshex[i] = valueshex[i] | (((uint32_t)receivedBytes[3 + (i * 4) + j]) << (24 - (8 * j)));
knightridar
Hi, Robin2's guide on parsing serial data was really usefull for me.
Serial Input Basics - Parsing Data
I was not using an array.
I used software serial to wirelessly transfer 4 analog values to another arduino by parsing the serial data:
Please see post #32 for transmitter and receiver code:
HC-12 TRANSMITTER TO HC-12 RECEIVER, CONVERT ANALOG VALUES BACK TO INTEGER
Hopefully it may be of help.
CAD files project portfolio
Useful files for Arduino, hobbyist, and engineering projects
https://grabcad.com/has-2
Robin2
#3
Apr 18, 2019, 09:38 am Last Edit: Apr 18, 2019, 09:39 am by Robin2
And what does it actually output?
Maybe you have the bytes for a multi-byte value in the wrong order?
If you create a struct with the proper datatypes then you can copy the array of received bytes directly into the struct and then just access the values in the struct. Something like (I may not have the syntax exactly correct)
memcpy(&structInstance, &receivedBytes, sizeof(structInstance))
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
PaulS
Is that a question or a statement?
If it is a question, how do you expect us to know what you think?
If it is a statement, why did you use a question mark?
