Topic: Degrees mapping 360deg formulas (Read 96 times) previous topic - next topic
slad1995
Hi all,
Im working on a project but cant seam to cum up with a solution to a issue im having.
im using poxzy sensor and from the imu i can get the orientation of the sensor but im having an issue with it would be reading 130 deg when i want to 90 to be read
so it would be easy reading_angle-40= 90 deg
but say if the reading_angle = 30 deg
my formula would be reading 30-40 = -10 deg
but i don't want to measure -10 deg i want 350 deg
anyone have a formula that i could use or any idea how i would solve this issue?
Thanks
Robin2
Something like ?
Code: [Select]
if (degreeVal < 0) {
   degreeVal += 360;
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Mampfi
There is a Function in the Arduino Core called map wich could do this, take a look here: https://www.arduino.cc/reference/en/language/functions/math/map/
