Topic: SX1276 library (Read 173 times) previous topic - next topic
mebab
Apr 19, 2019, 03:41 pm Last Edit: Apr 19, 2019, 03:50 pm by mebab
Hi everybody,
I have implemented an application based on using a LoRa shield, SX1276MB1MAS with Arduino101 and have been using the sx1272 library which I see is not including all the existing options available on SX1276.
I am looking for the best library for the node-to-node RX/TX. There are different libraries available for SX1276. Do you know the best one?
Thanks in advance for any help!
srnet
Which SX1272 library have you been using ?
$50SAT is now Silent (but probably still running)
http://www.50dollarsat.info/
http://www.loratracker.uk/
mebab
#2
Apr 19, 2019, 06:32 pm Last Edit: Apr 19, 2019, 08:54 pm by mebab
It was an older version of the following link. For example, neither older nor newer include Continuous operation mode of RX. They just have Single operation mode of RX:
https://os.mbed.com/teams/BTSSN-Projet-Drone-Imagerie-et-Telemetri/code/SX1272/
srnet
Ah, so a library called a SX1272 library that is also a SX1276 library.
No idea what you mean by;
"Continuous operation mode of RX. They just have Single operation mode of RX"
Can you explain ?
mebab
Please look at page 40 and 41 in the following address:
https://cdn-shop.adafruit.com/product-files/3179/sx1276_77_78_79.pdf
It is about two modes of packet reception.
srnet
I think you will have to check the various libraries to see whether the are using the 'Continuous ' mode. I dont recall a library mentioning you could flip between the two.
