Topic: Using the CHENBO 10kg load sensor but need a code (Read 76 times) previous topic - next topic
krodr026
I can't find a code for the load sensor I am using which is called 'CHENBO 10kg Load sensor' and if you type that in google it will show up, its a metal bar using a strain gauge. Does anyone know where I can find a code for this sensor?
Paul_KD7HB
What do you believe is the difference between a "load sensor" and a "strain gauge"?
Paul
hammy
 Your thing probably uses a conventional strain gauge , in which case a HX711 might be what you need.
