Topic: Help with BTS7960 43A Motor Driver (Read 236 times) previous topic - next topic
disal_jayaweera
I'm trying to connect a NEMA 23 2 Phase Hybrid Stepper Motor to an Arduino UNO via a Double BTS7960B DC 43A Stepper Motor Driver. I'm having difficulties as to how this should be done.Any ideas appreciated.
Links to above mentioned products;
Stepper Motor -
https://jkongmotor.en.made-in-china.com/product/uKBxHtyOELVh/China-2-Phase-Hybrid-Stepper-Motors-NEMA23-1-8-Degree-Jk57hs41-2804.html
Motor Driver -
https://www.hotmcu.com/large-current-motor-driver-module-bts7960-43a-p-266.html
Would appreciate if somebody could send a circuit diagram and a basic program so that I could verify whether the equipment I have works.
I'm new to anything Arduino related btw.
disal_jayaweera
Stepper Motor -
Motor Driver -
jremington
#2
Apr 20, 2019, 09:17 pm Last Edit: Apr 20, 2019, 09:17 pm by jremington
You need a stepping motor driver capable of more than 3 Amperes/phase,  not that brushed D.C. motor driver.
Robin2
#3
Apr 20, 2019, 10:14 pm Last Edit: Apr 23, 2019, 10:07 pm by Robin2
As well as what is in Reply #1 Reply #2, I don't believe that driver is capable of driving a stepper motor, I think you would need a pair of them.
In the list of stepper motors, which is the one that you have?
I suggest you get a stepper motor driver that can provide at least 50% more current than your chosen motor requires.
These links may help.
Stepper Motor Basics
Simple Stepper Code
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
JCA79B
#4
Apr 20, 2019, 10:45 pm Last Edit: Apr 20, 2019, 10:53 pm by JCA79B
That driver seems like way overkill for a 2.8A, 0.7Ω motor, is it able to limit current to protect motor from burnout with higher voltages?
MarkT
#5
Apr 22, 2019, 08:40 pm Last Edit: Apr 22, 2019, 08:40 pm by MarkT
That's not a stepper driver at all.  The stepper is a 0.9 ohm 2.8A stepper requiring something like a GeckoDriver or other such high current stepper driver unit.  It requires too much current to run from a single-chip stepper driver
and is far too low resistance to be voltage driven by any dual H-bridge.  It requires current drive.
jremington
This is the second time you have posted this question, with the same answer.
Keep trying, perhaps some day you will get the answer you want!
Coding Badly
@disal_jayaweera, please do not cross-post.  Threads merged.
