Topic: Why does the DMM make this circuit "work" ? (Power issues : servo & bluetooth) (Read 516 times) previous topic - next topic
wvmarle
Size is relative. The smallest inductor is huge compared to a 0805 resistor; especially if you want lower resistance. Typical 9-10mm diameter and some 12-15 mm high.
Electrolytic capacitors are likewise bulky.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
BabyGeezer
thing is the PCA9685 module handles the V+ (for each servo)
No it dosn't.
maybe i should have phrased it differently, i meant that the whole breakout module that the PCA9685 chip is on has just one pin (two in parallel actually) for the incoming V+, meaning that to insert a Pi circuit for each servo, one has to breakout the 3-pin male headers to achieve the setup of;
power supply -> Pi circuit 1 ->  +ve of servo 1
power supply -> Pi circuit 2 ->  +ve of servo 2
power supply -> Pi circuit 3->  +ve of servo 3
power supply -> Pi circuit 4->  +ve of servo 4
and so on.
Science is about explaining and predicting observed/observable/measurable phenomena - coming up with plausible/backable theories to explain the mechanisms behind the observations. It is built-up on accumulated scientific knowledge - (math, gathered data, physics, chemistry etc).
if the accumulation is unstructured and quite haphazard in its collection, it becomes quite inefficient and the knowledge is filled with (unknown) gaps.
Switching over to something else (eg. nrf24L01) when the existing device (hc-05) is expected to be workable is certainly an option. But, naturally - it is definitely advantageous to find out the reason(s) for a particular approach being currently unable to achieve your objective ----- which is why you asked about it, and which is good. This enters the area of electronics/electronic engineering, and working towards improving electronics knowledge and skills.
yes, this is more my objective than just getting a project to actually work.
it's been three years since i first bought a MPU-6050 module (with unsoldered headers) and i am still learning about all the basics of each part that goes into making a self-balancing robot, trying to make do with existing actuators and power supply options, and finding out why it is not suitable and then trying to make cheap setups work just on principle.
Grumpy_Mike
No.
You put the filter between the break out board and the servo.
Southpark
Which is to be avoided where possible. And there are gaps in knowledge.... which is why pursuit of science knowledge and methods is ongoing. Science and engineering and other disciplines have gotten us to this interesting technological stage.... I have no issues with the 'structure' and 'efficiency' side of things with science.
Chetan_
I just want to know which 3.3V regulator you used I am also with the same project.
Grumpy_Mike
No it is not.
Surface mount inductor on the left 0805 resistor on the right.
BabyGeezer
i'm still prototyping and haven't even settled on how to supply the power properly - at the moment i'm using the LD1117A(3v3) - it's a LDO type. (although also using a DC-DC step-down converter - based on LM2596 chip)
No.
so you mean like this ?
meanwhile, on your webpage that you linked, it says using inductance values of tens of milli-henries.
i've been calculating what length and radius of coil that would involve and it's *huge* !
is my current circuit really needing that high a value - i can't imagine that's what my DMM was "contributing" ?
what sort of inductance/choke levels would be reasonable for 6V spikes of 100mA ?
(is there a formula for this and what would the 'phenomena' be called ?)
Grumpy_Mike
No.
Like this:-
The square boxes are the servos.
Your right it wasn't so that suggests you don't need that much inductance so you only need a small value. That was a general purpose comment for heavy motors.
You can't say without first defining the period of the pulse and you don't know that.
This is called "inductive reactance" https://www.electronics-tutorials.ws/inductor/ac-inductors.html and is the effective resistance an inductor presents when fed with an AC signal. This is a pure inductance where the actual resistance is considered zero.
The formula is inductive reactance in ohms = 2 * Pi * f * L
where f is the frequency in Hz and L is the inductance in Henries
wvmarle
My 10 mH inductors are still the standard 10mm radius, 12mm tall. Not too bad. Ohmic resistance is increasing of course (I'm sure the larger the induction the thinner the wire used to be able to have more coils, so more resistance per length and more overall length) so I'm normally using 330µH for my filters. Just 2-3Ω so not too much losses.
BabyGeezer
No.
Like this:-
yes, that was kind of my original point about having to "insert" the Pi circuit and not being able to (be lazy and) "just plug in the servo connection" :P
i see - okay then, i'll try and hand make a coil just to see if it holds back the jitter.
(more to do with "see what happens" than designing the circuit ideally.)
by my calculation, a simple straight (air core) coil of 20mm radius, 10mm long with 20 turns should give about 63 micro-H. (that's already 2.5 meters of the enamel wire needed(!), i don't have any ferrite (nor iron) core - now i get the "don't bother making your own" comment !)
so, good'ol V=IR applies here where the (supressing) "resistance" required would be an equivalent of (6V / 100mA) = 60 Ohm ?
and if i can get the frequency; the (minimum) inductance would be L = 60 / (2*Pi * f)
would the inverse of the pulse(time) be considered the 'frequency' ?
(am just realizing that AC doesn't have to be a constant period, and that a "DC spike" is also AC !)
wvmarle
An inductor basically tries to keep the current constant - it uses energy stored in its magnetic field for that. That's also why you need that flyback diode on inductive loads: so the current can continue to flow.
When you have a pure DC current flowing, all you see is the ohmic resistance, as in the normal resistance of the wire used. Note that when the power is switched on the inductor resists, so current starts up a bit slower as the magnetic field builds up.
So it rejects all changes in current, that includes spikes. For the same reason an inductor has a much larger resistance for AC current - it changes all the time. This is normally called "impedance" which includes many more effects than just ohmic resistance.
Grumpy_Mike
Yes.
Reactance is just one aspect of impedance but for this application you don't care about impedance.
Without a ferrite core an air core inductor is too big and does not work as well as the ferrite is lossy and absorbs some of the energy in the spikes.
BabyGeezer
ok then - thanks a lot, Mike and wvmarle !
new adventures into the world of coils will have to be planned soon.
