Topic: Pin no 13 is not working (Read 88 times) previous topic - next topic
Mhatreroshan
After connecting led in pin no 13 and 12 and near gnd the main board led goes off or blink several time and the another connected  led not working
pert
We need to know exactly how you have your circuit wired up. Ideally you would provide us with a schematic (picture of a hand drawn diagram is fine).
sterretje
Are you using a current limiting resistor?
Sounds like you are not using one which will result in too much current being drawn from the pin and through the microcontroller which can result in a reset.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
