Topic: can somebody help me with error: espcomm_upload_mem failed (Read 123 times) previous topic - next topic
jiha
im using arduino ide 1.8.9, i use esp8266. i try to upload it many times but it still show the same error.
Code: [Select]
Sketch uses 363108 bytes (34%) of program storage space. Maximum is 1044464 bytes.
Global variables use 30080 bytes (36%) of dynamic memory, leaving 51840 bytes for local variables. Maximum is 81920 bytes.
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9/esptool.exe -vv -cd nodemcu -cb 115200 -cp COM13 -ca 0x00000 -cf C:\Users\User\AppData\Local\Temp\arduino_build_672315/UTHMstaffavailability.ino.bin
esptool v0.4.13-1-gf80ae31 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 115200
setting port from COM1 to COM13
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
An error occurred while uploading the sketch
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
warning: espcomm_sync failed
error: espcomm_open failed
Juraj
is the esp8266 in flashing mode activated by io 0 pulled down at boot?
what esp8266 module/board you use and how did you wire it and connect to USB?
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
jiha
i use nodemcu ep8266, i connect esp8266 to multiplexer 3-to-8 Line Decoder
jiha
'is the esp8266 in flashing mode activated by io 0 pulled down at boot?'
i'm not sure about this part, how to check ?
Juraj
on NodeMCU it is done automatically
ro which pins you wired the multiplexer?
https://electronics.stackexchange.com/questions/402066/esp8266-free-gpios-for-relay-switching/404845#404845
