Topic: Thermistor (Read 189 times) previous topic - next topic
renoks
Hello!
In my project i am using thersmistor, and to get real temperature value i am using Steinhart-Hart equation.
But i concluded that with this equation i can't mesure 0 0C, even to get 1 0C my thermistor resistance has to be over 100 000 Ohms, that also is very high value and thermistor does not offer so high resistance values.
T0 value = 298.15 K.
B value = 3435
R0 value = 10 000 Ohm
R value depends on thermistor, my thermistor at 25 0C is 10 000 ohms.
Does every one has used this temperature sensor on arduino and Steinhart-Hart equation to mesure temperature close to 0 0C and know how to do it?
jremington
#1
Apr 26, 2019, 12:37 am Last Edit: Apr 26, 2019, 12:38 am by jremington
Quote
The equation is for Kelvin, the international absolute temperature scale.
0 0C = 273.15 K
renoks
In equation i put Kelvins, after that i convert in 0C. That doesn't change anything.
wvmarle
Then what actual resistance does your thermistor give you when you place it in a bath of ice water?
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
renoks
18 000 ohms
wvmarle
Putting that number in the function above (which is not the Steinhart-Hart equation, by the way) gives a temperature of 10°C.
If I solve the function above for R, and calculate it for T=273K, I find R = 28,736Ω. Not exactly accurate, which is expected from the B-coefficient formula.
That 18k is expected for a thermistor with your beta coefficient (see e.g. the TTF3A103 curve on p.3). For accurate results, use a calibration table - most likely you can find a table of resistance vs temperature for your thermistor.
renoks
#6
Apr 26, 2019, 12:50 pm Last Edit: Apr 26, 2019, 12:52 pm by renoks
In my calculations 18K ohms gives 18,5 0C.
I don't know how you find R, but when i put 10K in equation i get exacly 25°C.
And at the datasheet at 0 °C resistance should be close to 30K.
wvmarle
I just entered the formula in a spreadsheet using the parameters you gave before, and that's the value I got.
The curve as given in the datasheet I linked to is for a thermistor with the same B-coefficient as yours, and it shows about 18k at 0°C.
If your data sheet says 30k at 0°C, it must have a different B-coefficient. Or they calculated the value based on the B-coefficient, but didn't actually measure it: if I enter 30000 in the formula above for R, it gives me a temperature of -1°C.
jremington
Take the time to calibrate your thermistor at three different temperatures, using this web calculator, and it will work well.
renoks
Thank you for answers, i got it!
wvmarle
Care to share the core of your problem and your solution? I'm curious.
