Topic: Configuring MLX90614 Sensor in PWM Mode (Read 125 times) previous topic - next topic
solble
Do any of you have any experience with using the MLX90614 in PWM mode?    I tried writing the recommended value, 0000001000000111, to the appropriate register, 0x02, but my sensor doesn't seem to have changed.  I still cannot read any analog voltage and SMBUS hasn't been disabled.  Similar code seems to work when I assess temperature, but I can't get this to work.
Code: [Select]
#include <i2cmaster.h>
  void setup(){
  i2c_init(); //Initialise the i2c bus
void loop(){
    int dev = 0x5A<<1;
    unsigned int data_l = 0;
    unsigned int data_h = 0;
    int pec = 0;
    i2c_start_wait(dev+I2C_WRITE);
    i2c_write(0x02); //Register Address to write to
    i2c_write(0x00); //Erase low byte (write 0)
    i2c_write(0x00); //Erase high byte (write 0)
    i2c_write(0x207);
    i2c_stop();
    i2c_write(0x02);
    i2c_rep_start(dev+I2C_READ);
    data_l = i2c_readAck(); //Read 1 byte and then send ack
    data_h = i2c_readAck(); //Read 1 byte and then send ack
    pec = i2c_readNak();
    i2c_stop();
    Serial.println(data_l, DEC);
    Serial.println(data_l, HEX);
    Serial.println(data_h, DEC);
    Serial.println(data_h, HEX);
Here are the PDFs where I got the recommended value and register.
Power_Broker
Are you trying to read an analog voltage output or are you trying to read a PWM duty cycle?
"The desire that guides me in all I do is the desire to harness the forces of nature to the service of mankind."
   - Nikola Tesla
solble
Hello,
I am trying to read the PWM output but accidentally referred to it as analog voltage.  I was under the assumption that I would need to take in the analog output of the 90614  PWM  pin into my MCU via an ADC and use MLX's provided equations to calculate the temperature.
Power_Broker
Nah, you should use the pulsin() function to determine the duty cycle. then you can correlate the duty cycle to temperature
   - Nikola Tesla
knut_ny
You write   0x207.   That's not a byte.
Ny
