Topic: User configuration file does not exist or is not a regular file, skipping (Read 157 times) previous topic - next topic
meowrhino
Hey there! I'm new to this arduino Board. I'm using Arduino in a MacBook Pro with iOS Mojave 10.14.4 and had been having this error
fork/exec /Users/manue/Library/Arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++: no such file or directory
Error compilando para la tarjeta Arduino Nano.
so i tried following these instructions:
https://forum.arduino.cc/index.php?topic=547545.0
Click the link on the line following File > Preferences > More preferences can be edited directly in the file. This will open the /Users/brunoloverius/Library/Arduino15 folder.
Delete all files and folders under the Arduino15 folder except for preferences.txt. Please be very careful when deleting things from your computer. When in doubt, back up!
Restart the Arduino IDE
and now got this error:
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/manue/.avrduderc"
         Using Port                    : /dev/cu.wchusbserial14120
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "/dev/cu.wchusbserial14120": No such file or directory
avrdude done.  Thank you.
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
so... Um... don't really know what to do. I've been trying several things and stuff but still cant get it. Has anyone got some idea of what to do?
pert
This is message is normal and expected. You can safely ignore it. The Arduino IDE comes with its own avrdude configuration file.
This is the error you need to be concerned about. You need to select the port of your Nano from the Arduino IDE's Tools > Port menu. Is /dev/cu.wchusbserial14120 listed on that menu?
