Have some code to read button presses from my Digital pins using internal pullup resistors. (will paste below)
When arduino is first powered on, I need it to print a static RGB value to all 70 of the WS2812 LEDs
Around Line 62 (starts referencing "case 0, case 1, case 2" etc),
I want it to set a static value of my WS2812 LEDs to a specified RGB value when it also is printing a serial command for each case, along the "Serial.println"
i.e. set LED's 0-30 to 155,100,3
I've gotten this far, but can't get the LED's to do anything yet.
#include <FastLED.h>
#define NUM_LEDS 70
#define LED_PIN 11
#define BRIGHTNESS 100
#define LED_TYPE WS2812
#define COLOR_ORDER GRB
struct CRGB leds[NUM_LEDS];
// CRGBArray<NUM_LEDS> leds;
//CRGBSet partA(leds(0,70)); // Define custom pixel range with a name.
//CRGBSet partB(leds(0,16)); // Define custom pixel range with a name.
//CRGBSet partC(leds(17,34)); // Define custom pixel range with a name.
//CRGBSet partD(leds(35,52)); // Define custom pixel range with a name.
//CRGBSet partE(leds(53,70)); // Define custom pixel range with a name.
//CHSV colorOne(255,255,255); // Define a custom color.
//CHSV colorTwo(255,130,0); // Define a custom color.
CRGB rgbvalwh(255,255,255);
CRGB rgbvalorg(255,130,0);
#define DEBOUNCE 10 // how many ms to debounce, 5+ ms is usually plenty
//define the buttons that we'll use.
byte buttons[] = {0, 2, 4, 6, 8, 9};
//determine how big the array up above is, by checking the size
#define NUMBUTTONS sizeof(buttons)
//track if a button is just pressed, just released, or 'currently pressed'
byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
byte previous_keystate[NUMBUTTONS], current_keystate[NUMBUTTONS];
byte i;
Serial.begin(9600); //set up serial port
Serial.print("Button checker with ");
Serial.print(NUMBUTTONS, DEC);
Serial.println(" buttons");
// Make input & enable pull-up resistors on switch pins
for (i=0; i< NUMBUTTONS; i++) {
pinMode(buttons[i], INPUT);
digitalWrite(buttons[i], HIGH);
//LED Code
delay( 1000 ); // power-up safety delay
FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
FastLED.setBrightness( BRIGHTNESS );
set_max_power_in_volts_and_milliamps(5, 500); // FastLED Power management set at 5V, 500mA.
fill_solid(leds, 70, rgbvalwh);
byte thisSwitch=thisSwitch_justPressed();
switch(thisSwitch)
case 0:
Serial.println("switch 1 just pressed"); break;
case 1:
Serial.println("switch 2 just pressed"); break;
case 2:
Serial.println("switch 3 just pressed"); break;
case 3:
Serial.println("switch 4 just pressed"); break;
case 4:
Serial.println("switch 5 just pressed"); break;
case 5:
Serial.println("switch 6 just pressed"); break;
void check_switches()
static byte previousstate[NUMBUTTONS];
static byte currentstate[NUMBUTTONS];
static long lasttime;
byte index;
if (millis() < lasttime) {
// we wrapped around, lets just try again
lasttime = millis();
if ((lasttime + DEBOUNCE) > millis()) {
// not enough time has passed to debounce
return;
// ok we have waited DEBOUNCE milliseconds, lets reset the timer
for (index = 0; index < NUMBUTTONS; index++) {
justpressed[index] = 0; //when we start, we clear out the "just" indicators
justreleased[index] = 0;
currentstate[index] = digitalRead(buttons[index]); //read the button
if (currentstate[index] == previousstate[index]) {
if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
// just pressed
justpressed[index] = 1;
else if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
justreleased[index] = 1; // just released
pressed[index] = !currentstate[index]; //remember, digital HIGH means NOT pressed
previousstate[index] = currentstate[index]; //keep a running tally of the buttons
byte thisSwitch_justPressed() {
byte thisSwitch = 255;
check_switches(); //check the switches & get the current state
for (byte i = 0; i < NUMBUTTONS; i++) {
current_keystate[i]=justpressed[i];
if (current_keystate[i] != previous_keystate[i]) {
if (current_keystate[i]) thisSwitch=i;
previous_keystate[i]=current_keystate[i];
return thisSwitch;
FastLED.show(); // Power managed display
