Topic: Saving AT Command to SD Card (Read 78 times) previous topic - next topic
MarcLeoden
I hope someone could help me on saving the received text from the gsm to sd card. I have an attached file of my code.
Lucario448
Dumping a data stream from a serial source is as simple as:
Code: [Select]
// Open the file for writting first
byte data;
while (Serial.available())
  data = Serial.read();
  dataFile.write(data);
  mySerial.write(data);//Forward what Serial received to Software Serial Port
while(mySerial.available())
  data = mySerial.read();
  Serial.write(data);//Forward what Software Serial received to Serial Port
This way data streams from both directions are logged and still correctly piped to each port.
